cdp per ethernet vlan
rabeder
hi,
if i have a gigabit ethernet wirh for example 10 vlans - one native vlan and 9 802.1q tagged vlan, is it possible, that cdp pakets are forwadet on all subinterfaces (vlans) and not only over the native vlan ?
this means i need the cdp information on all vlans, because there is a man ethernetprovider inbetween, and every vlan goes to a certain branchrouter.
thanks for any help
mchin345
Level 6
Level 6
Router# clear cdp counters --- Resets the traffic counters to zero.
Router(config)# interface {{type1 slot/port} | {port-channel number}}
Router(config-if)# cdp enable
Router# show cdp interface [{{type1 slot/port} | {port-channel number}}]
Use the above commands
