CEF configuration
skhirbash
I would like to get some clarification regarding CEF configuration on routers. I have enabled CEF golbally and verified that it is enabled on Fas1/0, which is connected to the LAN switch, and S0/0 (S0/0.1), which connected to the WAN link using frame-relay. The questions that I have are:
1- If CEF is enabled on the Fas1/0 interface on the router, do I need to do anything on the switch that connects to it?
2- If CEF is enabled on the S0/0 (S0/0.1)interface on the router, do I need to do be aware of any special configuration? Also, since serial interfaces don't have MAC addresses, why is CEF or or any type of route-caching is required?
Thanks in advance,
sK
Edison Ortiz
All valid questions and concerns which are well covered in these documents:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hisw_c/index.htm
HTH,
