CEF on ASR1000 series
GRANT3779
Hi CSC,
On the above routers, where is the cef switching happening? Is it on the SPA cards or does it happen on the esp?
Reading here
 https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipswitch_cef/configuration/xe-16/isw-cef-xe-16-book/isw-cef-enable-disable.html
It states ASR1000 only operate in dcef mode. My understanding of dcef is that it happens directly on line cards. Does this mean it happens on the SPA cards? If so, where does the ESP fit into the grand scheme of dcef and packet flows?
Reza Sharifi
When cef and/or dcef is enabled, the switching is done on the SPA card.  ESP takes care of control plane traffic, management traffic, firewall, NAT, QOS, etc..
Have a look at this document for more info on ESP.
https://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/datasheet-c78-731640.html
Reza Sharifi
Thanks Reza,
Out of interest, the ESP and SPA cards. Can the software in these be upgraded or is the SW fixed within these module?
As far as I know, the ESP and SPAs software is not upgradable.
