Cellular port is issue, particular commands are not working in Cisco C819G-U-K9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-05-2017 02:13 AM - edited 03-08-2019 10:51 AM
Cellular port is issue .Even particular commands are not working. Please find logs of the same and assist further..
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.06.05 13:41:13 =~=~=~=~=~=~=~=~=~=~=~=
User Access Verification
Username: tmbitd
Password:
TMB_ITD>en
Password:
TMB_ITD#
TMB_ITD#sh cell
TMB_ITD#sh cellular 0 all
TMB_ITD#
TMB_ITD#
TMB_ITD#sh cellular rad 0 rad
TMB_ITD#sh cellular 0 radio
TMB_ITD#
TMB_ITD#
TMB_ITD#
TMB_ITD#sh ip int brief
Cellular0 unassigned YES NVRAM down down
FastEthernet0 unassigned YES unset up down
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
GigabitEthernet0 unassigned YES NVRAM administratively down down
Serial0 unassigned YES NVRAM administratively down down
Vlan1 10.45.25.17 YES NVRAM down down
TMB_ITD#sh ver
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.3(3)M3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 28-May-14 07:24 by prod_rel_team
ROM: System Bootstrap, Version 15.1(4r)M, RELEASE SOFTWARE (fc1)
TMB_ITD uptime is 8 minutes
System image file is "flash:c800-universalk9-mz.SPA.153-3.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C819G-U-K9 (revision 3.0) with 492620K/31667K bytes of memory.
Processor board ID FGL184523FK
4 FastEthernet interfaces
1 Gigabit Ethernet interface
1 Serial(sync/async) interface
1 terminal line
1 Virtual Private Network (VPN) Module
1 Cellular interface
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 C819G-U-K9 FGL184523FK
License Information for 'c800'
License Level: advipservices Type: Permanent
Next reboot license Level: advipservices
TMB_ITD#
TMB_ITD#
TMB_ITD#sh diag
Slot 0:
C819G Mother board Port adapter, 7 ports
Port adapter is analyzed
Port adapter insertion time 00:07:58 ago
Hardware Crypto Engine Details:
The CHIP id is 0x20000
The SEC revision no is 0x1
EEPROM contents at hardware discovery:
Hardware Revision : 3.0
PCB Serial Number : FOC18336A79
Processor type : DD
Part Number : 73-13209-03
Board Revision : F0
Top Assy. Part Number : 800-34090-01
Fab Version : 03
Product (FRU) Number : C819G-U-K9
Version Identifier : V01
Chassis Serial Number : FGL184523FK
MAC Address block size : 32
Chassis MAC Address : 3462.88e0.d05e
CLEI Code : CMMFB00ARA
Deviation Number : 0
RMA Number : 0-0-0-0
RMA Test History : 00
RMA History : 00
Asset Identifier :
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 06 F3 41 03 00 C1 8B 46 4F 43 31 38 33
0x10: 33 36 41 37 39 09 DD 82 49 33 99 03 42 46 30 C0
0x20: 46 03 20 00 85 2A 01 02 03 CB 8A 43 38 31 39 47
0x30: 2D 55 2D 4B 39 89 56 30 31 20 C2 8B 46 47 4C 31
0x40: 38 34 35 32 33 46 4B 43 00 20 C3 06 34 62 88 E0
0x50: D0 5E C6 8A 43 4D 4D 46 42 30 30 41 52 41 88 00
0x60: 00 00 00 81 00 00 00 00 03 00 04 00 D9 03 40 C1
0x70: C2 CC 86 00 00 00 00 00 00 F3 00 30 40 A2 55 41
0x80: 00 14 42 00 00 F8 00 24 03 E8 1E 78 08 70 1F 40
0x90: 0C F8 1F A4 11 75 1F B8 15 E0 1F 80 1A 2C 1E DC
0xA0: 1E A5 1E AA 22 F6 1E C8 27 10 1E AA FF FF FF FF
0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
TMB_ITD#
TMB_ITD#
TMB_ITD#sh cell
TMB_ITD#sh cellular 0 run int cell
TMB_ITD#sh run int cellular 0
Building configuration...
Current configuration : 276 bytes
interface Cellular0
description *** GPRS CONNECTIVITY ***
ip address negotiated
ip virtual-reassembly in
encapsulation ppp
load-interval 30
dialer in-band
dialer string hspa-R7
dialer string india-r7
dialer-group 1
no peer default ip address
crypto map cmap
end
TMB_ITD#
TMB_ITD#
TMB_ITD#ex
TMB_ITD con0 is now available
Press RETURN to get started.
- Labels:
Other Switching
