change interface number - Question
Eli Levi
Frequent Visitor
Frequent Visitor
Hi Community,
I'm using Cisco Catalyst 3750 PoE-24 switch, this is the show run:
I would like to know if it's possible to change the interface number
from f4/0/1 to f0/1 and if yes then how?
Please help, Thank you.
Eli.
Leo Laohoo
The command is: switch 4 renumber 1
And then reboot the switch.
balaji.bandi
Is this switch is part of Stack ? if so you can not change.
If this switch is standalone one. there may be un running config configure switch provision with switch number 4
no switch stack-member-number provision command
write and reboot.
Test and advise.
BB
Leo Laohoo
