Changing Existing DHCP DNS Servers
leeharding1985
Hi All,
Complete Newbie when it comes to Cisco command line routers, trying to learn though...
Can someone give me a quick lesson on how to change the existing DNS Servers within DHCP please on a Cisco 800 series?
Config is as follows:
ip dhcp pool DHCP-POOL
   import all
   network 192.168.18.0 255.255.255.0
   default-router 192.168.18.254
   dns-server 192.168.10.2 83.256.23.424
   domain-name XXXX
   netbios-name-server 192.168.10.2
I wish to remove 83.256.23.424 and replace it with another DNS server
thank you
Lee
2 Accepted Solutions
Latchum Naidu
Hi Lee,
You can do that like below...
Router(config)# ip dhcp pool DHCP-POOL
Router(config-dhcp)# no dns-server 192.168.10.2 83.256.23.424
Router(config-dhcp)# dns-server 192.168.10.2 "another DNS server IP"
Router(config-dhcp)# exit
Please rate the helpful posts.
Naidu.
Yes... To write the configuration to NVRAM so that if the router get reaload anytime unknowingly the configuration will not loose.
Naidu.
10 Replies 10
Latchum Naidu
Hi Lee,
Naidu.
Thank you!
Completed after ive done the following copy running-config startup-config
Is that all I need to do?
Lee
Naidu.
Superb. I've rated. thanks for your help
Lee
You are most welcome Lee..... :-)
Sir newbie here, found this while going through to find solution for my problem.
I wan to extend DHCP
Currently I have,
ip dhcp pool mainpool
   network 20.20.20.0 255.255.252.0
   default-router 20.20.20.1
   dns-server 8.8.8.8
Want to change to
ip dhcp pool mail pool
   network 20.20.0.0. 255.255.224.0
   dns-server 8.8.8.8
How to I edit?
Similarly to what @Latchum Naidu mentioned but for the whole pool:
Router(config)#no ip dhcp pool mainpool    (to remove the pool that you have)
Router(config)#ip dhcp pool mail pool
Router((config-dhcp))#network 20.20.0.0. 255.255.224.0
Router(config-dhcp)#default-router 20.20.20.1
Router(config-dhcp)#dns-server 8.8.8.8
Kind regards,
Jon
Thanks Jon!
Is there any recommended things I have to do before or after making the changes.
I would just say that if you would like to reserve specific IP's, then its recommended to do this before you create the pool.
This is to avoid that, if clients are already configured to received IP's from the DHCP server, they might get assigned those IP's.
to perform this do:
Router(config)#ip dhcp excluded-address a.b.c.d (starting address) - for a specific IP
or
Router(config)#ip dhcp excluded-address a.b.c.d (low IP) a.b.c.d (high IP)  - for a range.
But then again, you can always reserve them after you create the pool and then do a "clear ip dhcp binding a.b.c.d" command.
Kind regards
Oh, forgot to add...
If this is in a production environment, and clients are connected, then you will need to inform them that they will need to renew their leases, otherwise they will keep the old lease until it makes a new request.
