Changing Ports
Rawa Salah
Dears
I have Cisco Switch Multilayer with the following specification :
"Cisco WS-C3560G-24TS ) "
(Version : 12.2(44r)SE8
Serial Num : FOC1621V057
please that ports are 1Gig , Can I change some ports of this Switch to 10Gig ? and how ? please guide me
InayathUlla Sharieff
Rawa,
You cant do that.
Inayath
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
As Inayath has noted, the 3750G cannot be upgraded to support 10g.  (The was one model of that series that did support a single 10g port.)
If you want to support 10g, you'll need to look at newer devices.  Some of the newer devices have 10g ports standard, some as optional modules.  Usually 10g ports will require a external module, but there are some that will support just 10g copper.  Also, some of the new ports might be SFP+, which can support 1g or 10g.
