Gig port
amit bhatnagar
Hello All ,
I am replacing old 2960 with new 2960-S series swicthes .In old enviorment we only had 10/100 ports but on new switch we only have Gig ports .
I was wondering if there is any option to limit the traffic to 100Mb on switch port without chardcoding the port to 100Full .
Thanks for help
Amit
JohnTylerPearce
Level 7
Level 7
Well, it should be running at auto duplex, so if you have 10/100 cards and not 10/100/1000 cards, it shoudl run at 100 full, via auto negoitation. Or I guess, you can always rate-limit the ports to 100.
Thanks John ,
Can you advise how can I rate limit port to 100
Well, even with rate limiting, that's not going to stop something getting full duplex. Do the users not have 10/100/1000 cards?
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
I believe, some newer switches will allow limiting port speed to 100Mbps without requiring 100/full hardcoded.  (I.e. believe they can "appear" as an auto 100 - "speed auto 10 100".)
Also believe 2960 can logically rate limit to 100 Mbps, but if hardware can work as described (above), that would be a better option.
If remote side isn't hard coded to 100/full but can't do gig, it should run at 100.  If it can do gig, is there an important reason to preclude it from doing so?
