changing the field dscp using the policy-map on Catalyst 6500
Viktoriya
I am a new in  Network Technologies and I'm still learning and I would be pleased to communicate with intelligent people.
Setting QoS on Catalyst 6506 I ran into the problem:
after attaching a policy-map, which catches the necessary packets (ACL according to IP Source and IP Destination) and remarks the field DSCP (set dscp ef) on the input direction on SVI, in fact, it turns out that the DSCP field is NOT changed, and the EXP field in the MPLS header is changed according to mls qos maps. The counters captured packets in policy-map grow (used commands: sh policy-map interface vl87 and sh mls qos ip vl87). The fact that the DSCP field is not overwritten confirmed by the dump (see the end of this message).
Also I attache the file with the plan of network and some comments.
Perhaps somebody has had the same problem, please help.
Thank you in advance)))
I will describe the issue in more details
Configuring physical port:
interface GigabitEthernet3/3
 switchport
 switchport trunk allowed vlan 87
 switchport mode trunk
 wrr-queue random-detect min-threshold 3 70 70 70 70 70 70 70 100
 wrr-queue cos-map 1 8 0
 wrr-queue cos-map 2 7 1
 wrr-queue cos-map 2 8 2
 wrr-queue cos-map 3 7 3
 wrr-queue cos-map 3 8 4
 priority-queue cos-map 1 5 6 7
 mls qos vlan-based
Configuring SVI:
interface Vlan87
 description SKAT_users
 ip vrf forwarding SKAT
 ip address 10.120.2.1 255.255.255.0
 service-policy input test2
Configuring Policy Map:
Policy Map test2
    Class test2
      set dscp ef
Class Map match-all test2
   Match access-group name test2
Extended IP access list test2
    10 permit ip host 10.120.2.2 host 10.120.1.2
the output of the command show:
sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9-M), Version 15.1(2)SY7, RELEASE SOFTWARE (fc4)
System image file is "sup-bootdisk:/s72033-adventerprisek9-mz.151-2.SY7.bin"
cisco WS-C6506-E (R7000) processor (revision 1.1) with 983008K/65536K bytes of memory.
sh module
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL08517BHU
  3   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX    SAD09050D8N
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAD121300EY
  6    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAD08290CJ7
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0012.7f51.3f64 to 0012.7f51.3f7b   2.1   12.2(14r)S5  15.1(2)SY7   Ok
  3  0013.7f2d.2b70 to 0013.7f2d.2b9f   1.0   8.4(1)       15.1(2)SY7   Ok
  5  001e.4aab.0c18 to 001e.4aab.0c1f   2.0   8.5(2)       15.1(2)SY7   Ok
  6  0011.936f.2b5c to 0011.936f.2b5f   1.5   12.2(18r)S1  15.1(2)SY7   Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAL085073J9  2.0    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAD1214074L  1.0    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAD121406GH  1.0    Ok
  6  Centralized Forwarding Card WS-F6700-CFC       SAL1318P93A  4.1    Ok
Mod  Online Diag Status
  1  Bypass
  3  Bypass
  5  Bypass
  6  Bypass
sh mls qos
  QoS is enabled globally
  Port QoS is enabled globally
  Policy marking depends on port_trust
  QoS ip packet dscp rewrite enabled globally
  QoS serial policing mode disabled globally
  Input mode for GRE Tunnel is Pipe mode
  Input mode for MPLS is Pipe mode
  QoS is vlan-based on the following interfaces:  Gi3/3  Te6/2
  QoS Trust state is DSCP on the following interface: Te6/2
  Vlan or Portchannel(Multi-Earl) policies supported: Yes
  Egress policies supported: Yes
  QoS 10g-only mode supported: Yes [Current mode: Off]
  Global Policy-map: ingress[]
sh mls qos maps
   policed-dscp-norm-burst-map:                                  (dscp= d1d2)
     d1 :  d2 0  1  2  3  4  5  6  7  8  9
      0 :    00 01 02 03 04 05 06 07 08 09
      1 :    10 11 12 13 14 15 16 17 18 19
      2 :    20 21 22 23 24 25 26 27 28 29
      3 :    30 31 32 33 34 35 36 37 38 39
      4 :    40 41 42 43 44 45 46 47 48 49
      5 :    50 51 52 53 54 55 56 57 58 59
      6 :    60 61 62 63
   policed-dscp-max-burst-map:                                  (dscp= d1d2)
      6 :    60 61 62 63
   dscp-cos-map:                                  (dscp= d1d2)
      0 :    00 00 00 00 00 00 00 00 01 01
      1 :    01 01 01 01 01 01 02 02 02 02
      2 :    02 02 02 02 03 03 03 03 03 03
      3 :    03 03 04 04 04 04 04 04 04 04
      4 :    05 05 05 05 05 05 05 05 06 06
      5 :    06 06 06 06 06 06 07 07 07 07
      6 :    07 07 07 07
   dscp-exp-map:                                  (dscp= d1d2)
      6 :    07 07 07 07
   cos-dscp-map:
         cos:   0  1  2  3  4  5  6  7
        dscp:   0  8 16 24 32 46 48 56
   precedence-dscp-map:
      ipprec:   0  1  2  3  4  5  6  7
   exp-dscp-map:
         exp:   0  1  2  3  4  5  6  7
sh queueing interface g3/3
Interface GigabitEthernet3/3 queueing strategy:  Weighted Round-Robin
  Queueing on Gi3/3: Tx Enabled Rx Enabled
Trust boundary disabled
  Port is untrusted
  Extend trust state: not trusted [COS = 0]
  Default COS is 0
    Queueing Mode In Tx direction: mode-cos
    Transmit queues [type = 1p3q8t]:
    Queue Id    Scheduling  Num of thresholds
       01         WRR                 08
       02         WRR                 08
       03         WRR                 08
       04         Priority            01
    WRR bandwidth ratios:  100[queue 1] 150[queue 2] 200[queue 3]
    queue-limit ratios:     50[queue 1]  20[queue 2]  15[queue 3]  15[Pri Queue]
    queue tail-drop-thresholds
    1     70[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    2     70[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    3     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    queue random-detect-min-thresholds
      1    40[1] 70[2] 70[3] 70[4] 70[5] 70[6] 70[7] 70[8]
      2    40[1] 70[2] 70[3] 70[4] 70[5] 70[6] 70[7] 70[8]
      3    70[1] 70[2] 70[3] 70[4] 70[5] 70[6] 70[7] 100[8]
    queue random-detect-max-thresholds
    WRED disabled queues:
    queue thresh cos-map
    1     1
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8      0
    2     1
    2     2
    2     3
    2     4
    2     5
    2     6
    2     7      1
    2     8      2
    3     1
    3     2
    3     3
    3     4
    3     5
    3     6
    3     7      3
    3     8      4
    4     1      5 6 7
    Queueing Mode In Rx direction: mode-cos
    Receive queues [type = 1q2t]:
       1         Standard            2
    1     100[1] 100[2]
    1     1      0 1 2 3 4 5 6 7
    1     2
  Packets dropped on Transmit:
    BPDU packets:  0
    queue thresh             dropped  [cos-map]
    1     8                  246598  [0 ]
    2     7                       0  [1 ]
    2     8                       0  [2 ]
    3     7                       0  [3 ]
    3     8                       0  [4 ]
    4     1                       0  [5 6 7 ]
  Packets dropped on Receive:
    BPDU packets:  0
    1     1                       0  [0 1 2 3 4 5 6 7 ]
sh ip vrf SKAT
  Name                             Default RD          Interfaces
  SKAT                             65000:90            Vl87
Statistics collection and analysis:
 Vlan87
  Service-policy input: test2
    class-map: test2 (match-all)
      Match: access-group name test2
      set dscp 46:
      Earl in slot 5 :
    1418106 bytes
    5 minute offered rate 256 bps
    aggregate-forwarded 1418106 bytes
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
sh mls qos ip vl87
   [In] Policy map is test2   [Out] Default.
 QoS Summary [IPv4]:      (* - shared aggregates, Mod - switch module)
          Int Mod Dir  Class-map DSCP  Agg  Trust Fl   AgForward-By   AgPoliced-By
                                       Id         Id
          Vl87  5  In      test2   46    2     No  0        1420758              0
When I ping with the TOS=0x20 (i.e. DSCP=cs1) from a HostA (ip=10.120.1.2), which is located behind the MPLS network (vrf SKAT), to HostB (ip=10.120.2.2), which is connected through the LAN network to this cs6506 (vrf SKAT) I see the ICMP request with TOS=0x20(i.e. DSCP=cs1) which after passing through the MPLS network arrives to HostВ unchanged fieldTOS=0x20(DSCP=cs1). This fact coincides with my expectations.
Dump on hostA:
17:16:22.888238 44:8a:5b:04:1c:a2 > 00:21:d8:10:5c:00, ethertype 802.1Q (0x8100), length 102: vlan 87, p 0, ethertype IPv4, (tos 0x20, ttl 64, id 53095, offset 0, flags [DF], proto ICMP (1), length 84)
    10.120.1.2 > 10.120.2.2: ICMP echo request, id 26405, seq 1, length 64
Dump on hostВ (access, P-bits are absent):
17:17:37.056589 00:18:74:b0:30:00 > 00:15:60:56:cc:e4, ethertype IPv4 (0x0800), length 98: (tos 0x20, ttl 63, id 6294, offset 0, flags [DF], proto ICMP (1), length 84)
    10.120.1.2 > 10.120.2.2ICMP echo request, id 26423, seq 1, length 64
Miracles begin in the opposite direction when forwarding ICMP echo reply from HostB to HostA. The HostB inserts the same tos value in the ICMP echo reply, but cs6506 does not overwrite the DSCP field to a value ef, as specified in the policy-map, and is transmitted through the MPLS network with TOS=0x20(i.e. DSCP=cs1), but at the same time, the EXP field in the MPLS header is overwritten according to mls qos maps.
Dump on hostB:
17:17:37.056639 00:15:60:56:cc:e4 > 00:18:74:b0:30:00, ethertype IPv4 (0x0800), length 98: (tos 0x20, ttl 64, id 38947, offset 0, flags [none], proto ICMP (1), length 84)
    10.120.2.2 > 10.120.1.2: ICMP echo reply, id 26423, seq 1, length 64
Dump on hostA:
17:16:22.888834 00:21:d8:10:5c:00 > 44:8a:5b:04:1c:a2, ethertype 802.1Q (0x8100), length 102: vlan 87, p 1, ethertype IPv4, (tos 0x20, ttl 63, id 22406, offset 0, flags [none], proto ICMP (1), length 84)
    10.120.2.2 > 10.120.1.2: ICMP echo reply, id 26405, seq 1, length 64
If I do a traceroute from HostB (ip=10.120.2.2) on HostA (ip=10.120.1.2) with a TOS=0x20(i.e. DSCP=cs1) I see Exp=5
traceroute from 10.120.2.1 to 10.120.1.2
1. 10.120.2.1
 2. 172.18.0.45
    [MPLS: Lbl 56 Exp 5 S 0 TTL 1]
    [MPLS: Lbl 1049 Exp 5 S 1 TTL 1]
 3. 172.18.0.10
    [MPLS: Lbl 1198 Exp 5 S 0 TTL 1]
 4. 10.120.1.1
 5. 10.120.1.2
cs1-6500#sh mls qos maps
      6 :    07 07 07 07
0 Replies 0
