channel-group mode for VSS MEC link to WLC
andrewswanson
Level 7
Level 7
Hello
I have a Cisco 5508 WLC with LAG enabled - this LAG connects to a single VSS chassis (VSS etherchannel mode is "on" as per the WLC documentation)
I'm looking to spread this LAG across both the VSS chassis - Cisco's VSS best practice document below states that for Multi Chassis Etherchannel "Do not use on and off options with PAgP or LACP or Trunk protocol negotiation"
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-virtual-switching-system-1440/109547-vss-best-practices.html
Is anyone else connecting a WLC LAG to a VSS MEC and if so what channel-group mode are they using?
Andy
Reza Sharifi
I have never connected a WLC to VSS, but WLC should be threaded just as an access switch and use LACP or PAgP to connect to both VSS switches.
