channel-misconfig
Rosa Ladeira
Hello.
I am working on migrating from cat6509 to cat6509-E.
I am trying to configure a TP ethernetchannel/trunk in order to change cats on the fly.
I have 2 trunks configured on the same cat. One trunk works on production.
The other don't (for migration).
WS-C6509 Software, Version NmpSW: 8.5(6)
Copyright (c) 1995-2006 by Cisco Systems
NMP S/W compiled on Aug 15 2006, 23:33:52
System Bootstrap Version: 7.1(1)
System Web Interface Version: Engine Version: 5.3.4 ADP Device: Cat6000 ADP Version: 8.0 ADK: 49
System Boot Image File is 'bootflash:cat6000-sup2cvk9.8-5-6.bin'
System Configuration register is 0x2
Hardware Version: 3.0  Model: WS-C6509  Serial #: TBM06124103
Cat6509-T#show version
Cisco IOS Software, s3223_rp Software (s3223_rp-IPBASE-VM), Version 12.2(33)SXH8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 28-Sep-10 19:51 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
Cat6509-T uptime is 5 days, 2 hours, 42 minutes
Uptime for this control processor is 5 days, 2 hours, 45 minutes
Time since Cat6509-T switched to active is 5 days, 2 hours, 45 minutes
System returned to ROM by s/w reset at 19:10:31 UTC Tue Nov 16 2010 (SP by power-on)
System image file is "sup-bootdisk:/s3223-ipbase-vz.122-33.SXH8.bin"
cisco WS-C6509-E (R7000) processor (revision 1.5) with 516096K/8192K bytes of memory.
Processor board ID SMG1443N008
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
18 Virtual Ethernet interfaces
48 FastEthernet interfaces
1 Gigabit Ethernet interface
2 Ten Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2142
Patching is not available since the system is not running from an installed image. To install please use the "install file" command
6509wc4> (enable) show port channel info trunk
Port  Trunk-status Trunk-type    Trunk-vlans
9/1  trunking     n-dot1q       1-4094
9/2  trunking     n-dot1q       1-4094
9/3  trunking     n-dot1q       1-4094
9/4  trunking     n-dot1q       1-4094
9/9  trunking     dot1q         1-4094
9/10 trunking     dot1q         1-4094
9/11 trunking     dot1q         1-4094
9/12 trunking     dot1q         1-4094
6509wc4> (enable)
Port  Status     Channel              Admin Ch
                 Mode                 Group Id
9/1  connected  on                     135  1666
9/2  connected  on                     135  1666
9/3  connected  on                     135  1666
9/4  connected  on                     135  1666
9/9  connected  on                       4  1670
9/10 connected  on                       4  1670
9/11 connected  on                       4  1670
9/12 connected  on                       4  1670
Port  Device-ID                       Port-ID                   Platform
9/1  TSC07040001(6509wc3)            4/11                      WS-C6509
9/2  TSC07040001(6509wc3)            4/10                      WS-C6509
9/3  TSC07040001(6509wc3)            4/12                      WS-C6509
9/4  TSC07040001(6509wc3)            4/13                      WS-C6509
9/9  Cat6509-T                       FastEthernet4/2           cisco WS-C6509-E
9/10 Cat6509-T                       FastEthernet4/3           cisco WS-C6509-E
9/11 Cat6509-T                       FastEthernet4/4           cisco WS-C6509-E
9/12 Cat6509-T                       FastEthernet4/5           cisco WS-C6509-E
6509wc4> (enable)
6509wc4> (enable)
6509wc4> (enable) 2011 Jun 29 16:30:59 BRST -03:00 %SPANTREE-2-CHNMISCFG: STP loop - channel 9/9-12 is disabled in vlan/instance 2
2011 Jun 29 16:30:59 BRST -03:00 %SPANTREE-2-CHNMISCFG2: BPDU source mac addresses: 00-08-a4-f4-5e-e6, 00-01-63-d7-0b-9a
2011 Jun 29 16:30:59 BRST -03:00 %ETHC-5-PORTFROMSTP:Port 9/9 left bridge port 9/9-12
2011 Jun 29 16:30:59 BRST -03:00 %DTP-5-NONTRUNKPORTON:Port 9/9 has become non-trunk
2011 Jun 29 16:30:59 BRST -03:00 %ETHC-5-PORTFROMSTP:Port 9/10 left bridge port 9/9-12
2011 Jun 29 16:30:59 BRST -03:00 %DTP-5-NONTRUNKPORTON:Port 9/10 has become non-trunk
2011 Jun 29 16:31:00 BRST -03:00 %ETHC-5-PORTFROMSTP:Port 9/11 left bridge port 9/9-12
2011 Jun 29 16:31:00 BRST -03:00 %DTP-5-NONTRUNKPORTON:Port 9/11 has become non-trunk
2011 Jun 29 16:31:00 BRST -03:00 %ETHC-5-PORTFROMSTP:Port 9/12 left bridge port 9/9-12
2011 Jun 29 16:31:00 BRST -03:00 %DTP-5-NONTRUNKPORTON:Port 9/12 has become non-trunk
6509wc4> (enable)
6509wc4> (enable) show port channel info trunk  ?
  |                          Output modifiers
  <cr>
9/9  not-trunking dot1q         1-4094
9/10 not-trunking dot1q         1-4094
9/11 not-trunking dot1q         1-4094
9/12 not-trunking dot1q         1-4094
6509wc4> (enable)
interface Port-channel1
switchport
shutdown
interface FastEthernet4/1
ip address 147.65.14.232 255.255.255.0
interface FastEthernet4/2
switchport
switchport mode trunk
interface FastEthernet4/3
switchport
interface FastEthernet4/4
switchport
interface FastEthernet4/5
switchport
interface FastEthernet4/6
no ip address
shutdown
6509wc4> (enable) show errdisable-timeout
ErrDisable Reason                       Timeout Status
arp-inspection                          enable
bcast-suppression                       enable
bpdu-guard                              enable
cam-monitor                             enable
channel-misconfig                       enable
crossbar-fallback                       enable
duplex-mismatch                         enable
ethernet-oam                            enable
gl2pt-ingress-loop                      enable
gl2pt-threshold-exceed                  enable
gl2pt-cdp-threshold-exceed              enable
gl2pt-eoam-threshold-exceed             enable
gl2pt-stp-threshold-exceed              enable
gl2pt-vtp-threshold-exceed              enable
link-inerrors                           enable
link-rxcrc                              enable
link-txcrc                              enable
packet-buffer-error                     enable
udld                                    enable
other                                   enable
Interval: 300 seconds
Port  ErrDisable Reason    Port ErrDisableTimeout  Action on Timeout
9/9  channel-misconfig    Enable                  Enabled
9/10 channel-misconfig    Enable                  Enabled
9/11 channel-misconfig    Enable                  Enabled
9/12 channel-misconfig    Enable                  Enabled
2 Accepted Solutions
   Please try this for testing.
switchport
channel-group 1 mode on
switchport
switchport
switchport
switchport
no shutdown
HTH,
Toshi
   It sounds a bit crazy please try using cross-over cables to connect between them. Please let me know what happens when you test connect those ports on switches with your notebook/pc. Do you see any light up at ports?  Hmm.. It says "not connect"
Toshi
37 Replies 37
switchport
switchport
switchport
switchport
switchport
no shutdown
HTH,
Toshi
Thanks a lot.
It seams it is workink fine.
                 Mode                 Group Id
6509wc4> (enable)
   I'm glad that I could help.
Toshi
Hi Toshi, I guess I am needing your help again.
I have continued migrating my backbone. I have finished 6509-C configuration.
I started step 2.
First of all, I move 3 trunk cables from 6509-B to 6509-C and could not close trunk
from B to C.
I have no idea what is going on.
Rosa
I have this on 6509-B:
show version
WS-C6509 Software, Version NmpSW: 8.5(2)
Copyright (c) 1995-2005 by Cisco Systems
NMP S/W compiled on Dec  6 2005, 20:22:19
System Bootstrap Version: 5.3(2)
System Boot Image File is 'bootflash:cat6000-supk9.8-5-2.bin'
Hardware Version: 3.0  Model: WS-C6509  Serial #: TSC07040001
show port channel
                 Mode                 Group Id
4/10 notconnect on                     321  1766
4/11 notconnect on                     321  1766
4/12 notconnect on                     321  1766
4/13 connected  on                     321  1766
4/10
4/11
4/12
4/13 TBM06124103(6509wc4)            9/4                       WS-C6509
show port trunk
* - indicates vtp domain mismatch
# - indicates dot1q-all-tagged enabled on the port
$ - indicates non-default dot1q-ethertype value
Port      Mode         Encapsulation  Status        Native vlan
1/1      auto         n-dot1q        trunking      1
4/13     on           dot1q          trunking      1
Port      Vlans allowed on trunk
1/1      1-1005,1024-4094
4/13     1-4094
Port      Vlans allowed and active in management domain
1/1      1-7,9-10,13-14,20-21,23,30,105-107,192,400
4/13     1-7,9-10,13-14,20-21,23,30,105-107,192,400
Port      Vlans in spanning tree forwarding state and not pruned
Can you post the configs of the interfaces on both sides?
Interfaces on 6509-C
Cat6509-T#show interfaces trunk module 4
Fa4/1               on           802.1q         other         1
Fa4/2               on           802.1q         other         1
Fa4/3               on           802.1q         other         1
Fa4/4               on           802.1q         other         1
Fa4/5               on           802.1q         other         1
Fa4/6               on           802.1q         other         1
Fa4/7               on           802.1q         other         1
Fa4/8               on           802.1q         other         1
Fa4/1               none
Fa4/2               none
Fa4/3               none
Fa4/4               none
Fa4/5               none
Fa4/6               none
Fa4/7               none
Fa4/8               none
Fa4/1               none
Fa4/2               none
Fa4/3               none
Fa4/4               none
Fa4/5               none
Fa4/6               none
Fa4/7               none
Fa4/8               none
Fa4/1               none
Fa4/2               none
Fa4/3               none
Fa4/4               none
Fa4/5               none
Fa4/6               none
Fa4/7               none
Fa4/8               none
Cat6509-T#
Cat6509-T#show interfaces summary
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface               IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
  FastEthernet4/1          0     0    0     0     0    0     0    0    0
  FastEthernet4/2          0     0    0     0     0    0     0    0    0
  FastEthernet4/3          0     0    0     0     0    0     0    0    0
  FastEthernet4/4          0     0    0     0     0    0     0    0    0
  FastEthernet4/5          0     0    0     0     0    0     0    0    0
  FastEthernet4/6          0     0    0     0     0    0     0    0    0
  FastEthernet4/7          0     0    0     0     0    0     0    0    0
  FastEthernet4/8          0     0    0     0     0    0     0    0    0
  FastEthernet4/9          0     0    0     0     0    0     0    0    0
  FastEthernet4/10         0     0    0     0     0    0     0    0    0
  FastEthernet4/11         0     0    0     0     0    0     0    0    0
  FastEthernet4/12         0     0    0     0     0    0     0    0    0
  FastEthernet4/13         0     0    0     0     0    0     0    0    0
  FastEthernet4/14         0     0    0     0     0    0     0    0    0
  FastEthernet4/15         0     0    0     0     0    0     0    0    0
  FastEthernet4/16         0     0    0     0     0    0     0    0    0
  FastEthernet4/17         0     0    0     0     0    0     0    0    0
  FastEthernet4/18         0     0    0     0     0    0     0    0    0
  FastEthernet4/19         0     0    0     0     0    0     0    0    0
  FastEthernet4/20         0     0    0     0     0    0     0    0    0
  FastEthernet4/21         0     0    0     0     0    0     0    0    0
  FastEthernet4/22         0     0    0     0     0    0     0    0    0
  FastEthernet4/23         0     0    0     0     0    0     0    0    0
  FastEthernet4/24         0     0    0     0     0    0     0    0    0
  FastEthernet4/25         0     0    0     0     0    0     0    0    0
  FastEthernet4/26         0     0    0     0     0    0     0    0    0
  FastEthernet4/27         0     0    0     0     0    0     0    0    0
  FastEthernet4/28         0     0    0     0     0    0     0    0    0
  FastEthernet4/29         0     0    0     0     0    0     0    0    0
  FastEthernet4/30         0     0    0     0     0    0     0    0    0
  FastEthernet4/31         0     0    0     0     0    0     0    0    0
  FastEthernet4/32         0     0    0     0     0    0     0    0    0
  FastEthernet4/33         0     0    0     0     0    0     0    0    0
  FastEthernet4/34         0     0    0     0     0    0     0    0    0
  FastEthernet4/35         0     0    0     0     0    0     0    0    0
  FastEthernet4/36         0     0    0     0     0    0     0    0    0
  FastEthernet4/37         0     0    0     0     0    0     0    0    0
  FastEthernet4/38         0     0    0     0     0    0     0    0    0
  FastEthernet4/39         0     0    0     0     0    0     0    0    0
  FastEthernet4/40         0     0    0     0     0    0     0    0    0
  FastEthernet4/41         0     0    0     0     0    0     0    0    0
  FastEthernet4/42         0     0    0     0     0    0     0    0    0
  FastEthernet4/43         0     0    0     0     0    0     0    0    0
  FastEthernet4/44         0     0    0     0     0    0     0    0    0
  FastEthernet4/45         0     0    0     0     0    0     0    0    0
  FastEthernet4/46         0     0    0     0     0    0     0    0    0
  FastEthernet4/47         0     0    0     0     0    0     0    0    0
  FastEthernet4/48         0     0    0     0     0    0     0    0    0
  TenGigabitEthernet5/1    0     0    0     0     0    0     0    0    0
  TenGigabitEthernet5/2    0     0    0     0     0    0     0    0    0
  GigabitEthernet5/3       0     0    0     0     0    0     0    0    0
  Port-channel1            0     0    0     0     0    0     0    0    0
  Vlan1                    0     0    0     0     0    0     0    0    0
  Vlan2                    0     0    0     0     0    0     0    0    0
  Vlan3                    0     0    0     0     0    0     0    0    0
  Vlan4                    0     0    0     0     0    0     0    0    0
  Vlan5                    0     0    0     0     0    0     0    0    0
  Vlan6                    0     0    0     0     0    0     0    0    0
  Vlan7                    0     0    0     0     0    0     0    0    0
  Vlan9                    0     0    0     0     0    0     0    0    0
  Vlan10                   0     0    0     0     0    0     0    0    0
  Vlan13                   0     0    0     0     0    0     0    0    0
  Vlan14                   0     0    0     0     0    0     0    0    0
  Vlan20                   0     0    0     0     0    0     0    0    0
  Vlan21                   0     0    0     0     0    0     0    0    0
  Vlan23                   0     0    0     0     0    0     0    0    0
  Vlan155                  0     0    0     0     0    0     0    0    0
  Vlan192                  0     0    0     0     0    0     0    0    0
Cat6509-T#show interface Port-channel 1 status
Port         Name               Status       Vlan       Duplex  Speed Type
Po1                             notconnect   unassigned   auto   auto
Cat6509-T#show interface Fast 4/4 statu
Fa4/4        *** Cat6509-3 <--- notconnect   1            auto   auto 10/100BasX
Cat6509-T#show interface Fast 4/3 statu
Fa4/3        *** Cat6509-3 <--- notconnect   1            auto   auto 10/100BasX
Cat6509-T#show interface Fast 4/2 statu
Fa4/2        *** Cat6509-3 <--- notconnect   1            auto   auto 10/100BasX
Cat6509-T#show interface Fast 4/1 statu
Fa4/1        *** Cat6509-3 <--- notconnect   1            auto   auto 10/100BasX
Cat6509-T#
vlan 2
name administrativa
vlan 3
name sbm
vlan 4
name pesquisadores
vlan 5
name publica
vlan 6
name visgraf
vlan 7
name fluid
vlan 10
name servidores
vlan 11
name hpc
vlan 13
name alunos
vlan 14
name netadm
vlan 20
name transmissao
vlan 21
name roteadores-internos
vlan 23
name obmep
vlan 30
name telefonia
vlan 105
name wireless-clients
vlan 106
name cisco-aps
vlan 107
name network-printers
vlan 168
name splan
vlan 192
name internet
vlan 254
name roteadores-externos
vlan 931
name velox
switchport
description *** Cat6509-A <---> Cat6509-C ***
switchport
switchport
switchport
switchport
switchport
shutdown
switchport
shutdown
interface FastEthernet4/7
switchport
shutdown
interface FastEthernet4/8
switchport
shutdown
interface FastEthernet4/9
no ip address
shutdown
interface FastEthernet4/10
no ip address
shutdown
interface FastEthernet4/11
no ip address
shutdown
interface FastEthernet4/12
no ip address
shutdown
interface FastEthernet4/13
no ip address
shutdown
interface FastEthernet4/14
no ip address
shutdown
interface FastEthernet4/15
no ip address
shutdown
interface FastEthernet4/16
no ip address
shutdown
interface FastEthernet4/17
no ip address
shutdown
interface FastEthernet4/18
no ip address
shutdown
interface FastEthernet4/19
no ip address
shutdown
interface FastEthernet4/20
no ip address
shutdown
interface FastEthernet4/21
no ip address
shutdown
interface FastEthernet4/22
no ip address
shutdown
interface FastEthernet4/23
no ip address
shutdown
interface FastEthernet4/24
no ip address
shutdown
interface FastEthernet4/25
no ip address
shutdown
interface FastEthernet4/26
no ip address
shutdown
interface FastEthernet4/27
no ip address
shutdown
interface FastEthernet4/28
no ip address
shutdown
interface FastEthernet4/29
no ip address
shutdown
interface FastEthernet4/30
no ip address
shutdown
interface FastEthernet4/31
no ip address
shutdown
interface FastEthernet4/32
no ip address
shutdown
interface FastEthernet4/33
no ip address
shutdown
interface FastEthernet4/34
no ip address
shutdown
interface FastEthernet4/35
no ip address
shutdown
interface FastEthernet4/36
no ip address
shutdown
interface FastEthernet4/37
no ip address
shutdown
interface FastEthernet4/38
no ip address
shutdown
interface FastEthernet4/39
no ip address
shutdown
interface FastEthernet4/40
no ip address
shutdown
interface FastEthernet4/41
no ip address
shutdown
interface FastEthernet4/42
no ip address
shutdown
interface FastEthernet4/43
no ip address
shutdown
interface FastEthernet4/44
no ip address
shutdown
interface FastEthernet4/45
no ip address
shutdown
interface FastEthernet4/46
no ip address
shutdown
interface FastEthernet4/47
no ip address
shutdown
interface FastEthernet4/48
no ip address
shutdown
interface TenGigabitEthernet5/1
no ip address
shutdown
interface TenGigabitEthernet5/2
no ip address
shutdown
interface GigabitEthernet5/3
no ip address
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan2
no ip address
shutdown
interface Vlan3
no ip address
shutdown
interface Vlan4
no ip address
shutdown
interface Vlan5
no ip address
shutdown
interface Vlan6
no ip address
shutdown
interface Vlan7
no ip address
shutdown
interface Vlan9
no ip address
shutdown
interface Vlan10
no ip address
shutdown
interface Vlan13
no ip address
shutdown
interface Vlan14
description vlan netadm
ip address 127.95.4.232 255.255.255.0
ip pim sparse-mode
ip flow ingress
no ip mroute-cache
shutdown
interface Vlan20
no ip address
shutdown
interface Vlan21
no ip address
shutdown
interface Vlan23
no ip address
shutdown
interface Vlan155
no ip address
shutdown
interface Vlan192
no ip address
shutdown
6509-A
6509wcA> (enable) show port channel
                 Mode                 Group Id
4/10
4/11
4/12
6509wcA> (enable) show trunk
4/13     1-4094
6509-B
6509wcB> (enable) show port channel
                 Mode                 Group Id
9/1  notconnect on                     135  1666
9/2  notconnect on                     135  1666
9/3  notconnect on                     135  1666
9/9  notconnect on                       4  1670
9/10 notconnect on                       4  1670
9/11 notconnect on                       4  1670
9/12 notconnect on                       4  1670
9/1
9/2
9/3
9/9
9/10
9/11
9/12
6509wcB> (enable) sh port trunk
9/4      auto         n-dot1q        trunking      1
15/1      nonegotiate  isl            trunking      1
9/4      1-4094
15/1      1-4094
9/4      1-7,9-10,13-14,20-21,23,30,105-107,192,400
15/1
15/1
6509wc4> (enable)
  Sorry for my late reply. Please tell me what exactly you want to do.
1. Do you want to connect C6500A and C6500B with 3 trunk interfaces bounding to a channel-group. Right?
2. Do you want to connect C6500A and C6500B with 1 trunk interface. Right?
   Please post configuration on 3 devices and provide portmapping.Lets say Port10-12 on C6500A will be connected to Port10-12 on C6500B
HTH,
Toshi
I already have 1 tp trunk A + B.
I would llike to have at least 1 tp trunk A+C.
A config
Cat6509-A> (enable) show vlan
VLAN Name                             Status    IfIndex Mod/Ports, Vlans
1    default                          active    5       1/2
                                                        4/1,4/9-12,4/14-16
                                                        6/1-48
                                                        7/36-37
                                                        8/1-48
2    administrativa                   active    90      4/3
                                                        5/1,5/8,5/10-16,5/20-21,5/26-27,5/30
                                                        7/34
3    sbm                              active    91
4    pesquisadores                    active    92      5/2-3,5/5-7,5/19,5/25,5/28,5/35
                                                        7/1-5,7/7-11,7/13-19,7/27,7/31,7/35
5    publica                          active    93      5/4,5/9,5/17-18,5/29,5/31-34,5/36-48
                                                        7/6,7/22,7/24-26,7/28-30,7/32-33
6    visgraf                          active    94      7/12,7/45-48
7    fluid                            active    95      5/22-24
9    teste                            active    260
10   servidores                       active    96      7/21
13   alunos                           active    97
14   netadm                           active    98      4/2,4/4-5,4/7-8
                                                        7/42-44
20   transmissao                      active    99      4/6
                                                        7/41
21   roteadores                       active    100
23   obmep                            active    108     7/20
30   telefonia                        active    261
105  wireless-clients                 active    265     7/40
106  cisco-aps                        active    266     7/38-39
107  network-printers                 active    267     7/23
192  internet                         active    112
400  upload_ios                       active    102
1002 fddi-default                     active    6
1003 trcrf-default                    active    9
1004 fddinet-default                  active    7
1005 trbrf-default                    active    8       1003
1006 Online Diagnostic Vlan1          active    0       internal
1007 Online Diagnostic Vlan2          active    0       internal
1008 Online Diagnostic Vlan3          active    0       internal
1009 Voice Internal Vlan              active    0       internal
1010 Dtp Vlan                         active    0       internal
1011 OAM Remote Loopback Vlan         active    0       internal
1012 Private Vlan Internal Vlan       suspend   0       internal
1016 Online SP-RP Ping Vlan           active    0       internal
VLAN Type  SAID       MTU   Parent RingNo BrdgNo Stp  BrdgMode Trans1 Trans2
30   enet  100033     1500  -      -      -      -    -        0      0
1002 fddi  101002     1500  -      -      -      -    -        0      0
1003 trcrf 101003     4472  1005   0xccc  -      -    srb      0      0
1004 fdnet 101004     1500  -      -      -      -    -        0      0
1005 trbrf 101005     4472  -      -      0xf    ibm  -        0      0
VLAN AREHops STEHops Backup CRF 1q VLAN
1003 7       7       off
Cat6509-A> (enable)
Cat6509-A> (enable)
Cat6509-A> (enable) show port channel
                 Mode                 Group Id
4/10
4/11
4/12
Cat6509-A> (enable)
Cat6509-A> (enable)
Cat6509-A> (enable) show trunk
4/13     1-4094
Cat6509-A> (enable)
Cat6509-A> (enable)
Cat6509-A> (enable) show port 4/10
* = Configured MAC Address
# = 802.1X Authenticated Port Name.
4/10                      notconnect 1            auto        auto 10/100/1000
Port  AuxiliaryVlan AuxVlan-Status
4/10 none          none
Port  Security Violation Shutdown-Time Age-Time Max-Addr Trap     IfIndex
4/10 disabled  shutdown             0        0        1  enabled      35
Port  Flooding on Address Limit Last-Src-Addr     Vlan
4/10                   Enabled                 -    -
Port  Num-Addr Secure-Src-Addr     Vlan Age-Left Shutdown/Time-Left
4/10        0                 -      -        -        -         -
Port  802.1X Auth-State   802.1X Port-Status
4/10 -                   -
Port  Mac-Auth-Bypass State  Mac-Auth-Bypass Port-Status
4/10 Disabled               (null)
Port     Broadcast-Limit Multicast Unicast Total-Drop           Action
4/10                  -         -       -                    0 drop-packets
Port  Send FlowControl  Receive FlowControl   RxPause    TxPause
      admin    oper     admin     oper
4/10 desired  off      off       off         0          0
                 Mode                 Group Id
Port  Status      ErrDisable Reason    Port ErrDisableTimeout  Action on Timeout
4/10 notconnect                    -  Enable                  No Change
Port  Align-Err  FCS-Err    Xmit-Err   Rcv-Err    UnderSize
4/10          0          0          0          0         0
Port  Single-Col Multi-Coll Late-Coll  Excess-Col Carri-Sen Runts     Giants
4/10          0          0          0          0         0         0         0
Port  Last-Time-Cleared
4/10 Fri Jul 8 2011, 07:28:44
Idle Detection
Cat6509-A> (enable)  show port 4/11
4/11                      notconnect 1            auto        auto 10/100/1000
4/11 none          none
4/11 disabled  shutdown             0        0        1  enabled      36
4/11                   Enabled                 -    -
4/11        0                 -      -        -        -         -
4/11 -                   -
4/11 Disabled               (null)
4/11                  -         -       -                    0 drop-packets
4/11 desired  off      off       off         0          0
                 Mode                 Group Id
4/11 notconnect                    -  Enable                  No Change
4/11          0          0          0          0         0
4/11          0          0          0          0         0         0         0
4/11 Fri Jul 8 2011, 07:28:44
Idle Detection
Cat6509-A> (enable)  show port 4/12
4/12                      notconnect 1            auto        auto 10/100/1000
4/12 none          none
4/12 disabled  shutdown             0        0        1  enabled      37
4/12                   Enabled                 -    -
4/12        0                 -      -        -        -         -
4/12 -                   -
4/12 Disabled               (null)
4/12                  -         -       -                    0 drop-packets
4/12 desired  off      off       off         0          0
                 Mode                 Group Id
4/12 notconnect                    -  Enable                  No Change
4/12          0          0          0          0         0
4/12          0          0          0          0         0         0         0
4/12 Fri Jul 8 2011, 07:28:44
Idle Detection
Cat6509-A> (enable)
Cat6509-A> (enable) show port 4/13
4/13                      connected  trunk      a-full       a-1Gb 10/100/1000
4/13 none          none
4/13 disabled  shutdown             0        0        1  enabled      38
4/13                   Enabled                 -    -
4/13        0                 -      -        -        -         -
4/13 force-authorized    authorized
4/13 Disabled               (null)
4/13                  -         -       -                    0 drop-packets
4/13 desired  off      off       off         0          0
                 Mode                 Group Id
4/13 connected                     -  Enable                  No Change
4/13          0          0          0          0         0
4/13          0          0          0          0         0         0         -
4/13 Fri Jul 8 2011, 07:28:44
Idle Detection
Cat6509-A> (enable) show port capabilities ?
                        Module number, range 1..9,15-16
                   Module number and Port number(s)
  |                          Output modifiers
Cat6509-A> (enable) show port capabilities 4/10
Model                       WS-X6516-GE-TX
Port                        4/10
Type                        10/100/1000
Auto MDIX                   yes
AuxiliaryVlan               1..4094,untagged,dot1p,none
Broadcast suppression       percentage(0-100)
Channel                     yes
COPS port group             not supported
CoS rewrite                 yes
Dot1q-all-tagged            yes
Dot1x                       yes
Duplex                      half,full
Fast start                  yes
Flow control                receive-(off,on,desired),send-(off,on,desired)
Inline power                no
Jumbo frames                yes
Link debounce timer         yes
Link debounce timer delay   no
Membership                  static,dynamic
Port ASIC group             4/9-12
Port VLAN Mapping           Group: 4/9-12     Maximum Allowed Mappings: 32
Port VLAN Mapping           Supported Trunk Type: dot1q
QOS scheduling              rx-(1p1q4t),tx-(1p2q2t)
Security                    yes
SPAN                        source,destination
Speed                       auto,10,100,1000,auto-10-100
Sync restart delay          no
ToS rewrite                 no
Trunk encap type            802.1Q,ISL
Trunk mode                  on,off,desirable,auto,nonegotiate
UDLD                        yes
Cat6509-A> (enable) show port capabilities 4/11
Port                        4/11
Type                        10/100/1000
Auto MDIX                   yes
Channel                     yes
CoS rewrite                 yes
Dot1x                       yes
Duplex                      half,full
Fast start                  yes
Inline power                no
Jumbo frames                yes
Security                    yes
ToS rewrite                 no
UDLD                        yes
Cat6509-A> (enable) show port capabilities 4/12
Port                        4/12
Type                        10/100/1000
Auto MDIX                   yes
Channel                     yes
CoS rewrite                 yes
Dot1x                       yes
Duplex                      half,full
Fast start                  yes
Inline power                no
Jumbo frames                yes
Security                    yes
ToS rewrite                 no
UDLD                        yes
Cat6509-A> (enable) show port capabilities 4/13
Port                        4/13
Type                        10/100/1000
Auto MDIX                   yes
Channel                     yes
CoS rewrite                 yes
Dot1x                       yes
Duplex                      half,full
Fast start                  yes
Inline power                no
Jumbo frames                yes
Port ASIC group             4/13-16
Port VLAN Mapping           Group: 4/13-16     Maximum Allowed Mappings: 32
Security                    yes
ToS rewrite                 no
UDLD                        yes
Cat6509-A> (enable)
C config
Cat6509-C#show running-config
Building configuration...
Current configuration : 6283 bytes
upgrade fpd auto
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service counters max age 5
hostname Cat6509-C
boot-start-marker
boot system flash sup-bootdisk:/s3223-ipbase-vz.122-33.SXH8.bin
boot-end-marker
username rosa privilege 15 password 7 10431D0D1547115B1F
username netadm privilege 15 password 7 03094F1F165F221C5D
no aaa new-model
clock timezone BRST -3
ip subnet-zero
no ip domain-lookup
ip flow-cache timeout active 1
ip flow ingress layer2-switched vlan 2-7,13-14,20-21
vtp domain impa
vtp mode transparent
call-home
alert-group configuration
alert-group diagnostic
alert-group environment
alert-group inventory
alert-group syslog
mls aging long 64
mls aging normal 64
mls netflow interface
mls flow ip interface-full
no mls flow ipv6
no mls acl tcam share-global
mls cef error action freeze
redundancy
keepalive-enable
mode sso
main-cpu
  auto-sync running-config
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
system flowcontrol bus auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
vlan 2
name administrativa
vlan 3
name sbm
vlan 4
name pesquisadores
vlan 5
name publica
vlan 6
name visgraf
vlan 7
name fluid
vlan 10
name servidores
vlan 11
name hpc
vlan 13
name alunos
vlan 14
name netadm
vlan 20
name transmissao
vlan 21
vlan 23
name obmep
vlan 30
name telefonia
vlan 105
vlan 106
name cisco-aps
vlan 107
vlan 168
name splan
vlan 192
name internet
vlan 254
vlan 931
name velox
switchport
description *** Cat6509-3 <---> Cat6509-C ***
switchport
switchport
switchport
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
Cat6509-C#show interfaces fastEthernet 4/1 trunk
Fa4/1               none
Fa4/1               none
Fa4/1               none
Cat6509-C#show interfaces fastEthernet 4/2 trunk
Fa4/2               none
Fa4/2               none
Fa4/2               none
Cat6509-C#show interfaces fastEthernet 4/3 trunk
Fa4/3               none
Fa4/3               none
Fa4/3               none
Cat6509-C#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa4/1, Fa4/2, Fa4/3
3    sbm                              active
5    publica                          active
6    visgraf                          active
7    fluid                            active
11   hpc                              active
13   alunos                           active
14   netadm                           active
21   roteadores-internos              active
23   obmep                            active
30   telefonia                        active
168  splan                            active
192  internet                         active
254  roteadores-externos              active
931  velox                            active
1002 fddi-default                     act/unsup
1003 trcrf-default                    act/unsup
1004 fddinet-default                  act/unsup
1005 trbrf-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
4    enet  100004     1500  -      -      -        -    -        0      0
5    enet  100005     1500  -      -      -        -    -        0      0
6    enet  100006     1500  -      -      -        -    -        0      0
7    enet  100007     1500  -      -      -        -    -        0      0
10   enet  100010     1500  -      -      -        -    -        0      0
11   enet  100011     1500  -      -      -        -    -        0      0
13   enet  100013     1500  -      -      -        -    -        0      0
14   enet  100014     1500  -      -      -        -    -        0      0
20   enet  100020     1500  -      -      -        -    -        0      0
21   enet  100021     1500  -      -      -        -    -        0      0
23   enet  100023     1500  -      -      -        -    -        0      0
30   enet  100030     1500  -      -      -        -    -        0      0
105  enet  100105     1500  -      -      -        -    -        0      0
106  enet  100106     1500  -      -      -        -    -        0      0
107  enet  100107     1500  -      -      -        -    -        0      0
168  enet  100168     1500  -      -      -        -    -        0      0
192  enet  100192     1500  -      -      -        -    -        0      0
254  enet  100254     1500  -      -      -        -    -        0      0
931  enet  100931     1500  -      -      -        -    -        0      0
1003 trcrf 101003     4472  1005   3276   -        -    srb      0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trbrf 101005     4472  -      -      15       ibm  -        0      0
1003 7       7       off
Remote SPAN VLANs
Primary Secondary Type              Ports
Cat6509-C#show interfaces fastEthernet 4/3 status
FastEthernet4/3 is down, line protocol is down (notconnect)
  Hardware is C6k 100Mb 802.3, address is 0008.a4f4.5ee6 (bia 0008.a4f4.5ee6)
  Description: *** Cat6509-3 <---> Cat6509-C ***
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 0/255, rxload 0/255
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
Cat6509-C#show interfaces fastEthernet 4/3 etherchannel
Port state    = Down Not-in-Bndl
Channel group = 1           Mode = On      Gcchange = -
Port-channel  = null        GC   =   -         Pseudo port-channel = Po1
Port index    = 0           Load = 0x00        Protocol =    -
Age of the port in the current state: 0d:23h:44m:41s
Cat6509-C#show interfaces fastEthernet 4/2 etherchannel
Age of the port in the current state: 0d:23h:44m:57s
Cat6509-C#show interfaces fastEthernet 4/1 etherchannel
Age of the port in the current state: 0d:23h:45m:04s
Cat6509-C#show interface port-channel 1
Port-channel1 is down, line protocol is down (notconnect)
  Hardware is EtherChannel, address is 0000.0000.0000 (bia 0000.0000.0000)
  Auto-duplex, Auto-speed, media type is unknown
  input flow-control is off, output flow-control is off
     0 output errors, 0 collisions, 3 interface resets
Cat6509-C#show interface port-channel 1 statu
Cat6509-C#show interface port-channel 1 status
Cat6509-C#show interfaces fast 4/1
FastEthernet4/1 is down, line protocol is down (notconnect)
  Hardware is C6k 100Mb 802.3, address is 0008.a4f4.5ee4 (bia 0008.a4f4.5ee4)
Cat6509-C#show interfaces fast 4/1 capabilities
FastEthernet4/1
  Model:                 WS-X6348-RJ-45
  Type:                  10/100BaseTX
  Speed:                 10,100,auto
  Duplex:                half,full
  Trunk encap. type:     802.1Q,ISL
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on),tx-(none)
  Membership:            static
  Fast Start:            yes
  QOS scheduling:        rx-(1q4t), tx-(2q2t)
  QOS queueing mode:     rx-(cos), tx-(cos)
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          yes
  Inline power policing: no
  SPAN:                  source/destination
  UDLD                   yes
  Link Debounce:         yes
  Link Debounce Time:    no
  Ports on ASIC:         1-12
  Remote switch uplink:  no
  Dot1x:                 no
  Port-Security:         yes
Cat6509-C#show interfaces fast 4/1 ether
Cat6509-C#show interfaces fast 4/1 etherchannel
Age of the port in the current state: 0d:23h:47m:28s
Cat6509-C#show interfaces fast 4/2 etherchannel
Age of the port in the current state: 0d:23h:48m:02s
Cat6509-C#show interfaces fast 4/3 etherchannel
Age of the port in the current state: 0d:23h:48m:11s
Cat6509-C#show interface port-channel 1 etherchannel
Age of the Port-channel   = 0d:23h:45m:57s
Logical slot/port   = 14/1          Number of ports = 0
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel Ag-Not-Inuse
Protocol            =    -
Fast-switchover     = disabled
Load share deferral = disabled
Cat6509-C#show interface port-channel 1 capabilities
Port-channel1
  Model:                 NO IDPROM
  Type:                  unknown
  Speed:                 10,100,1000,auto
  Duplex:                half,full
  Channel:               yes
  Flowcontrol:           rx-(off,on,desired),tx-(off,on,desired)
  Membership:            static
  Fast Start:            yes
  QOS scheduling:        rx-(NotDef-t), tx-(NotDef-t)
  QOS queueing mode:     rx-(none), tx-(none)
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          no
  UDLD                   no
  Link Debounce:         no
  Ports on ASIC:         UNAVAILABLE
  Dot1x:                 no
  Port-Security:         no
FastEthernet4/1
  Type:                  10/100BaseTX
  Speed:                 10,100,auto
  Duplex:                half,full
  Channel:               yes
  Membership:            static
  Fast Start:            yes
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          yes
  UDLD                   yes
  Link Debounce:         yes
  Ports on ASIC:         1-12
  Dot1x:                 no
  Port-Security:         yes
Fa4/1               none
Fa4/1               none
Fa4/1               none
Fa4/2               none
Fa4/2               none
Fa4/2               none
Fa4/3               none
Fa4/3               none
Fa4/3               none
Cat6509-C#show interfaces port-channel 1 trunk
Po1                 on           802.1q         other         0
Po1                 none
Po1                 none
Po1                 none
Cat6509-C#show interfaces fastEthernet 4/1 switchport brief
Port        Status     Op.Mode  Op.Encap Channel-id Vlan
Fa4/1       notconnect  none     native   Po1         1    (default )
Cat6509-C#
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down (suspended member of bundle Po1)
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Operational Native VLAN tagging: disabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Cat6509-C#show interfaces fastEthernet 4/2 switchport
Switchport: Enabled
Voice VLAN: none
Cat6509-C#show interfaces fastEthernet 4/3 switchport
Switchport: Enabled
Voice VLAN: none
Cat6509-C#show interfaces port-channel 1 switchport
Switchport: Enabled
Access Mode VLAN: unassigned
Trunking Native Mode VLAN: 0 (Inactive)
Voice VLAN: none
Cat6509-C#
Thanks a lot.
Rosa
Hi Rosa,
   You didn't tell me which physical ports you want to do.
SwicthA and SwitchB - let's say SwitchA use Fast4/4 and SwitchB use Fast4/4
########SwitchA
switchport
########SwitctchB
switchport
SwicthA and SwitchC - let's say SwitchA use Fast4/1- Fast4/3 and SwitchC use Fast4/1- Fast4/3 . Assuming that you've not used channel-group3 on both devices. And you will in this case.
#########SwitchA
switchport
channel-group 3 mode on
switchport
switchport
interface Port-channel3
switchport
no shutdown
##########SwitchC
switchport
switchport
switchport
switchport
no shutdown
HTH,
Toshi
Hi Toshi, thanks again.
I think this is a little bit more complicated that I could explain.
Let's take a look at this picture:
6509-A and 6509-B run CATOS. 6509-C runs IOS.
I had trunk from 9/1-4 A ports to 4/10-13 B ports done as well.
I had trunk from  9/9-12 B ports to 4/2-5 C ports.
Then, on the fly, I had unpluged trunk from B to C.
Immediately, I got the form bellow. I am not able to restore initial conditions.
6509A> (enable) show port channel
                 Mode                 Group Id
4/10
4/11
4/12
6509A> (enable)
6509B> (enable) show port channel
                 Mode                 Group Id
9/1
9/2
9/3
9/9
9/10
9/11
9/12
6509B> (enable)
From this on, I started trying to establish a trunk from 4/10-12 A ports (CATOS) to 4/1-3 C ports (IOS) and I can't.
                 Mode                 Group Id
4/10
4/11
4/12
6509A>
I guess  that the key of the problem relays on :
as shown bellow:
6509C#show interfaces fastEthernet 4/1 switchport
Switchport: Enabled
Voice VLAN: none
Switchport: Enabled
Voice VLAN: none
6509C>
switchport
description *** Cat6509A <---> Cat6509C ***
switchport
switchport
description *** Cat6509A <---> Cat650C ***
switchport
6509C>
    Which ports on 6509A that you want to connect with 6509C? Are you going to use on Port4/1 - 4/4 on 6509C to connect 6509A? Please post configuration on 6509A and 6509C.
Toshi
R:
I guess  that the key of the problem relays on 4/1 C port :
____________________________________ A config:______________________________________________
6509A> (enable) show port trunk
4/13     1-4094
                 Mode                 Group Id
4/10
4/11
4/12
6509A> (enable)
____________________________________ C config:______________________________________________
Switchport: Enabled
Voice VLAN: none
6509C#show interfaces port-channel 1 switchport
Switchport: Enabled
Voice VLAN: none
6509C>
switchport
switchport
switchport
switchport
6509C>
   Please provide "show running" on 6509A.
Toshi
