channel-protocol command and 2950 switch
sarahr202
Level 5
Level 5
Hi every body!
My book says newer switches support pagp and lacp. Old switches such as 2950 support only pagp.As a result," channel-protocol " command is not available.
Does it mean on cisco 2950 switch, i can only configure:
channel-group 1 mode on or auto or desirable?
thanks a lot!
Roberto Salazar
Level 8
Level 8
yes, switches that does not support LACP have no reason to have "channel-protocol" command therefore it would not be there.
However, I would like to point out that Cat 2950 support LACP too beginning 12.1(13)EA1. The older switches like 2900XL or 3500XL does not siupport LACP at all, maybe that's what they meant?
Here is a 2950 that is running a newer IOS:
2950#conf t
Enter configuration commands, one per line. End with CNTL/Z.
2950(config)#int range fa 0/1 - 2
2950(config-if-range)#channel-protocol ?
lacp Prepare interface for LACP protocol
pagp Prepare interface for PAgP protocol
2950(config-if-range)#do show ver
IOS (tm) C2950 Software (C2950-I6K2L2Q4-M), Version 12.1(22)EA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
as you can see it does support LACP.
Roberto Salazar
Level 8
Level 8
2950#conf t
