check a port for errors
piotrkrol
hi
howto check a port from Catalyst WS-C3550-12T for errors ?
kind regards
piotr
JORGE RODRIGUEZ
Level 10
Level 10
Piotr, from cli issue " show interface "
if you are particularly looking for specific interface issue "show interface fastethernet0/#" where # is the port number.
the "show interface fastethernet0/3"
will show interface stats for port 3, look for input errors, CRC, Runts, Giants statistics as these are indicators of communications errors between the port and the connected system. Same principle applies for gigabit interfaces if you have any uplinks. " show interface gigabitethernet0/#.
Jorge
Jorge Rodriguez
JORGE RODRIGUEZ
Level 10
Level 10
Jorge
Jorge Rodriguez
