Check FEC counters on nexus 3232
I'm seeing a lot of FEC corrected words in an arista 7060 connected to a nexus 3232 and would like to know if there is a command to check that in cisco.
Output from arista:
localhost#show inter et58/4 phy detail
Ethernet58/4
Current State Changes Last Change
PHY state linkUp 12 0:01:22 ago
Interface state up 10 0:01:21 ago
HW resets 0 never
Transceiver 100GBASE-PSM4 8 0:01:28 ago
Transceiver SN SOZ131iF0123
Oper speed 25Gbps
Interrupt Count 1
Transceiver Reset Count 0 never
Transceiver Interrupt Count 2 0:01:24 ago
Transceiver Smbus Failures 0 0:10:02 ago
Diags mode normalOperation
Model Bcm56870 (A)
Loopback none
Xcvr EEPROM read timeout 0 never
Spurious xcvr detection 0 never
DOM control/status fail 0
Presence indication xcvrPresent 11 0:01:35 ago
Bad EEPROM checksums 0 never
RX_LOS since system boot False 8 3:45:29 ago
RX_LOS since insertion 0
TX_FAULT since system boot False 0 never
TX_FAULT since insertion 0
PMA/PMD RX signal detect ok 3 0:00:35 ago
Forward Error Correction Reed-Solomon
Reed-Solomon codeword size 528
FEC alignment lock ok 0 never
FEC corrected codewords 78669 17 0:00:00 ago
FEC uncorrected codewords 0 0 never
FEC lane corrected symbols
Lane 0 78807 17 0:00:00 ago
FEC lane mapping
FEC lane 00 01 02 03
PMA lane 00 00 00 00
PCS RX link status up 9 0:01:26 ago
PCS high BER ok 0 never
PCS BER 39 1 4:56:50 ago
PCS error blocks 18 4:56:50 ago
Lane 3
RXPPM CLK90 CLKP1 PF(M,L) VGA DCO DFE(1,2,3,4,5,6) TXPPM TXEQ(n1,m,p1,2,3)
0 29 -1 0,1 12 5 3,-15, 0, -1, 0, 1 0 10, 65, 0, 0, 0
localhost#
hard to find anything about FEC counters. The only option I could find was to configure:
forward-error-correction cl91-rs-fec
on the interface (with the default being that the forward-error-correction value is inherit)...
