Ciaco 3550 Source Port Based ACL's are not Matching PBR
Josh-Hill
Config:
route-map PLEX-SERVICE permit 10
match ip address PLEX-ACL
set ip next-hop 192.168.1.187
ip access-list extended PLEX-ACL
permit tcp host 192.168.10.10 eq 32400 any
permit tcp host 192.168.4.12 eq 32400 any
# sh sdm prefer
The current template is the default extended-match template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1K VLANs.
number of unicast mac addresses: 5K
number of igmp groups: 1K
number of qos aces: 1K
number of security aces: 1K
number of unicast routes: 4K
number of multicast routes: 1K
interface Vlan10
description Virtual Vlan 10
ip address 192.168.10.2 255.255.255.0
ip policy route-map PLEX-SERVICE
interface Vlan4
description HPN-DMZ
ip address 192.168.4.1 255.255.255.0
Logs
*Mar 1 00:21:21.067: IP: s=192.168.10.10 (Vlan10), d=192.168.10.255, len 78, policy rejected -- normal forwarding
*Mar 1 00:21:21.815: IP: s=192.168.10.10 (Vlan10), d=192.168.10.255, len 78, policy rejected -- normal forwarding
*Mar 1 00:21:22.043: IP: s=192.168.10.10 (Vlan10), d=192.168.10.255, len 49, policy rejected -- normal forwarding
*Mar 1 00:21:22.567: IP: s=192.168.10.10 (Vlan10), d=192.168.10.255, len 78, policy rejected -- normal forwarding
So when i apply the ACL to the vlan interface directly i get match's (verified through the log command) so i know the ACL is correct. However when i use this ACL with the above Route-Map it does not catch. I have read at a few forums that on some switches you wont see the hits however i am not seeing outbound traffic on the network hop interfaces. Nor is my dummy ACL's incrementing.
Mark Malone
sdm looks right , policy looks right
shot in the dark but did you try alter the acl just incase its having an issue I know it working in general but incase policy is not catching it right for some reason in software
try reorganize it
permit tcp host 192.168.10.10  any eq 32400
permit tcp host 192.168.4.12 any eq 32400
or change it too different type acl
access-list 199 permit tcp host 192.168.10.10  any eq 32400
You never now whats triggering it not to be caught could try if the 192.168.1.187 is not already in route table set ip default next-hop see if that catches it instead
if you have already tried options like this I would change the software just in case upgrade the ios
