Cisco 1300-8fp-2g
jerry2025
Is the cisco Cisco SFP-10G-T compatible with the 1300-8fp-2g?
Thank you!
M02@rt37
hello @jerry2025
Please refer here:
https://tmgmatrix.cisco.com/?npid=6098
no 10Giga !!!
Best regards
5 Replies 5
jerry2025
i wanted to add that the media switches from copper to fiber when ethernet cable is inserted.
Cisco1300#20-Feb-2025 17:07:19 %LINK-W-Down: gi9
20-Feb-2025 17:07:19 %LINK-W-Down: Vlan 1
20-Feb-2025 17:07:23 %LINK-I-CHNGCOMBOMEDIA: Media changed from copper media to fiber media on port gi9.
@jerry2025
 As per the data sheet, this switch is not Ten Giga.
C1300-8FP-2G
10 x Gigabit Ethernet
8 x Gigabit Ethernet
2 x Gigabit Ethernet combo
C1300-8FP-2G
C1300-8FP-2G
●  8x 10/100/1000 PoE+ ports with 120W power budget
●  2x Gigabit copper/SFP combo ports
●  Rack-mountable
Leo Laohoo
1300-8FP-2G will not support 10 Gbps optics.
vishalbhandari
@jerry2025 No, the Cisco SFP-10G-T (10GBASE-T) module is not compatible with the CBS1300-8FP-2G switch. The CBS1300-8FP-2G has two SFP uplink ports, but these ports only support 1G SFP modules, not 10G SFP+ modules. If you need a copper uplink, you should use a 1G copper SFP instead, like the GLC-T module.
M02@rt37
hello @jerry2025
Please refer here:
no 10Giga !!!
Best regards
