Cisco 1710
aconticisco
Level 2
Level 2
is this router good to connect to my adsl so that I replace it instead of the basic modem thet the ISP gives you ?
WIll it help for the new ccnp exam ?
The router is EoL and very old.
But, if it works and you just want to use it as a replacement for a basic modem/lab usage I don't see a problem.
I'm pretty sure the router is not capable of a lot of features that are now part of the CCNP exams, but you can use it for many other things.
Federico.
Federico.
