cisco 1711 not detecting any wic's
anand.narine1
I have installed working wic1-enet and wic1-dsu-t1 cards but they do not show up when i run
sh ip int br
or
sh int
neither on bootup :
Cisco IPM (MPC862P) processor (revision 0x101) with 91879K/6425K bytes of memory.
Processor board ID FOC09140S4A (3865132210), with hardware revision 0000
MPC862P processor: part number 7, mask 0
1 FastEthernet interface
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
the wic0 and wic1 lights on the router are green when i have inserted the cards, they just dont show up in the console.
router has 96 ram / 32 flash, and 1 built in Fa0 interface.
c1700-advipservicesk9-mz.124-25d.bin
Sandeep Choudhary
HI Annand,
Can u plz tell us the exact name of wic card???
I already did.
HI Anand,
AS per this docs:
https://supportforums.cisco.com/docs/DOC-1927
http://www.cisco.com/web/ANZ/cpp/refguide/hview/router/1700.html
To work, the WIC-1ENET card must be installed in slot0
WIC1-ENET supported on 1700series router with these IOS:Cisco IOS versions 12.1(3)XT, 12.1(5)YB, 12.2(2)XJ, 12.2(4)T
Hope it helps.
apparently the 1711 is a fixed configuration router and will only work with the wic4-esw card and an isdn card.
i used wic1-enet cards in both slots on 1720 and 1721 routers.
