Cisco 1721, multiple wan failover not working when first ISP cable is pulled out
popescu.mircea
I have the following curious situation:
on a cisco 1721, I have 2 ISP (ISP1 and ISP2). The router is configured to automatically use ISP2 if ISP1 goes down (see bellow for the config).
.... and it does in the following situations:
1. If the fa0.3 is disabled (# no interface fa0.3)
2. if the ip of ISP1 is changed with a random ip that is not accepted by the provider
     conf t
     interface fa0.3
     ip address zz.zz.zz.zz
BUT, this failover config, DOES NOT WORK when I, phisically, pull out the cable of ISP1
This is so weird
Can anyone help?
_________________________________________________________________
Building configuration...
Current configuration : 2529 bytes
version 12.4
service password-encryption
hostname xxxxx_CORE
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
username netmaster privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxx
track timer interface 5
interface Ethernet0
no ip address
ip virtual-reassembly
shutdown
half-duplex
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
speed auto
full-duplex
no keepalive
interface FastEthernet0.2
description ISP2
encapsulation dot1Q 2
ip address xx.xx.xx.xx 255.255.255.252
ip nat outside
no ip route-cache
interface FastEthernet0.3
description ISP1
encapsulation dot1Q 3
ip address yy.yy.yy.yy 255.255.255.0
ip nat outside
no ip route-cache
interface FastEthernet0.6
description Subinterfata pentru VLAN-ttttttt
encapsulation dot1Q 6
ip address 10.0.0.1 255.255.255.0
ip nat inside
no ip route-cache
ip policy route-map NOFAILOVER
interface FastEthernet0.7
description Subinterfata pentru VLAN-zzzzzzz
encapsulation dot1Q 7
ip address 10.0.1.1 255.255.255.0
no ip route-cache
interface FastEthernet0.11
description "vlan NATIV. Nu se foloseste"
encapsulation dot1Q 11 native
no ip route-cache
ip route 0.0.0.0 0.0.0.0 xx.xx.xx.1 10
ip route 0.0.0.0 0.0.0.0 yy.yy.yy.241 20
no ip http server
no ip http secure-server
ip nat log translations syslog
ip nat inside source route-map ISP1 interface FastEthernet0.2 overload
ip nat inside source route-map ISP2 interface FastEthernet0.3 overload
ip nat inside source route-map NOFAILOVER interface FastEthernet0.2 overload
access-list 101 permit ip 10.0.0.128 0.0.0.15 any
access-list 101 permit ip host 10.0.0.17 any
access-list 102 permit ip host 10.0.0.84 any
route-map NOFAILOVER permit 10
match ip address 102
set ip next-hop yy.yy.yy.241
route-map ISP2 permit 10
match ip address 101
match interface FastEthernet0.3
route-map ISP1 permit 10
match interface FastEthernet0.2
control-plane
line con 0
line aux 0
line vty 0 4
login local
transport input ssh
end
Andrew Cink
The problem is, the router can tell if your next hop device is responding, but not farther than that. So for example, if your DSL modem is pingable, but the DSL to the internet is down, as long as the DSL modem's ethernet interface is working, the router thinks it's working.
You need something to track an IP out on the internet, so it can tell if the entire path is up. Try this for example...
http://www.youtube.com/watch?v=1TivtZcZHEQ
Andy
chad patterson
The problem actually is that you are not using a Service Level Agreement to track the state of the interfaces. You seem to have everything else right though. The follwing statements wil set your router as an OER (Optimized Edge Router). If it's too much there is a simpler way just using IP SLA. Try adding this:
ip sla 1
icmp-echo xx.xx.xx.xx source-interface FastEthernet0.2
timeout 1000
threshold 40
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo yy.yy.yy.yy source-interface FastEthernet0.3
timeout 1000
threshold 40
frequency 3
ip sla schedule 2 life forever start-time now
key chain OER
key 1
  key-string oerkey
oer master
max-range-utilization percent 88
border 1.1.1.1 key-chain OER
  interface FastEthernet0.2 external
   max-xmit-utilization absolute 8000
  interface FastEthernet0.3 external
  interface FastEthernet0/0 internal
learn
  throughput
  periodic-interval 88
  aggregation-type prefix-length 32
mode route control
mode select-exit best
resolve range priority 1
resolve utilization priority 2 variance 1
oer border
local Loopback0
master 1.1.1.1 key-chain OER
track 100 interface FastEthernet0.2 ip routing
delay down 15 up 10
track 200 interface FastEthernet0.3 ip routing
delay down 15 up 10
interface Loopback0
ip address 1.1.1.1 255.255.255.0
no ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0.2 track 100
ip route 0.0.0.0 0.0.0.0 FastEthernet0.3 track 200
You might be better off to replace the interface name with the static ip address in the ip route command. If you do not, your memory will fragment quickly, to which the solution is:
ip nat translation tcp-timeout 3600
