PBR is not working
onlinerecharge
Dear All,
I have created a PBR in 3650 switch to route traffic from a specific IP address to a specific next hop or IP address(Router)
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
SW1 uptime is 6 weeks, 2 days, 16 minutes
System image file is "flash:/c3560-ipservicesk9-mz.150-1.SE2.bin"
access-list 101 permit ip host 192.168.170.92 10.10.10.0 0.0.0.255
route-map MPLS permit 101
match ip address 101
set ip next-hop 192.168.170.4
The next hop router is connected to this switch directly and member of vlan 170,
I am getting the following error
*Apr 13 23:48:25.104: %PLATFORM_PBR-4-SDM_MISMATCH: PBR requires sdm template routing
I also enable "
sdm prefer routing"   but still not working.
any sugestion please
6 Replies 6
jj27
Did you place the route map on the ingress interface (I assume L3 SVI for 192.168.170.0 network) for the traffic?
interface vlanXX
ip policy route-map MPLS
yes also did this already but still not working.
Did you reboot the switch after you enabled the sdm prefer routing?
It is required when you issue that command.
sdm prefer takes effect upon reboot.
no......ok i will reboot the switch and let you know....can you tell me ,,it there any issue that can be create after enabling sdm frefer routing
it changes the allocation of TCAM memory. I imagine you should be fine. Ive never had an issue when changing it.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00801e7bb9.shtml
