Cisco 1750 & 1751 flash memory maximum upgrade capacity?
azmirccnp
Hi guys,
Need your help on this. Can I know, what is the maximum flash memory capacity can I upgrade on Cisco 1750 & 1751. I need to use minimum 32M of flash memory to upgrade my routers to IOS version 12.3 and up.
And also can I upgrade the memory to 64M? I think there is no problem with the memory upgrade, only concern about the flash upgrade. Especially for 1750 routers.
Thanks.
mohammedmahmoud
Level 11
Level 11
Hi there,
For the 1750 router:
Flash memory - Type: onboard (socketed) miniflash card; default: 4 MB; available sizes: 4, 8, 16 MB; maximum flash: 16 MB; support dual flash bank.
maximum DRAM: 48 MB
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080092102.html
For the 1751:
Cisco 1751 Flash - 32 MB/32 MB
RAM 64 MB/128 MB
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088719.html
HTH, please rate if it does,
Mohammed Mahmoud.
Hi Mohammed, thanks for your answers. I've a Cisco 1751 with Flash of 16M, can I upgrade it to 32M?
And also, for the 1750, I can't upgrade it to Flash 32M & RAM 64M ??
Thanks.
