Cisco 1805 VLAN problem
jcclubb15
Ok so I believe I have done everything right so any help would be greatly appreciated. Attached is my running config. I have the et0/0 set up for dhcp because it's connected to the outside network, the switch interface connected to vlan 2 which has a static ip, and i've also given my computer a static ip.
milan_ver
So What is the issue ???
I'm getting no internet connection to my host computer
Hi Jeremiah,
There is not enough information here to be able to help you.
If you are using Fa0/0 as the uplink - where is NAT being performed? On the provider device?
If you need help I would need to see a diagram or a further explanation of the topology you are working in.
Thanks!
