Cisco 1811 - configuration
OSJF2009SDL
I have configured my Cisco 1811 router (Lab environemnt) as follows:
VPN settings for remote clients
crypto isakmp client configuration group 3000client
key XXXXXX
dns 8.8.8.8
domain cisco.local
pool ippool
acl 108
VLAN settings
interface FastEthernet7
switchport access vlan 108
interface FastEthernet8
switchport access vlan 100
interface FastEthernet9
switchport access vlan 66
interface Vlan66
ip address 192.168.7.252 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan100
ip address 10.10.10.1 255.255.255.248
ip nat inside
interface Vlan108
ip address 10.10.10.9 255.255.255.248
Split-tunnel ACL for VPN clients
access-list 108 permit ip 10.10.10.0 0.0.0.7 14.1.1.0 0.0.0.255
NAT ACL for VPN and local VLANs
ip nat inside source route-map NONAT interface Dialer0 overload
access-list 112 deny   ip 10.10.10.0 0.0.0.7 14.1.1.0 0.0.0.255
access-list 112 deny   ip 192.168.7.0 0.0.0.255 14.1.1.0 0.0.0.255
access-list 112 permit ip 10.10.10.0 0.0.0.7 any
route-map NONAT permit 10
match ip address 112
I underestand 10.10.10.7 is the broadcast address of Vlan100.
When I connect a VPN client and ping the remote VLAN 10.10.10.1 and then ping 10.10.10.7, the output is as follows:
Pinging 10.10.10.1 with 32 bytes of data:
Reply from 10.10.10.1: bytes=32 time=50ms TTL=255
Pinging 10.10.10.7 with 32 bytes of data:
Reply from 85.176.X.X: bytes=32 time=55ms TTL=255
Question #1: I understand ACL 112 does NAT for 10.10.10.1-6 but not 10.10.10.7. How sould ACL 112 look like?
Question #2: Is it normal to get a reply when you ping a broadcast address at all?
Any help is appreciated!
Kind Regards,
Sebastian
OSJF2009SDL
Answer to Question #2
From: http://support.microsoft.com/?scid=kb%3Ben-us%3B137421&x=14&y=16
RFC-1122 Section 3.2.2.6  Echo Request/Reply
"An ICMP Echo Request destined to an IP broadcast or IP multicast     address MAY be silently discarded.
