Cisco 1841 Config Help
xr5054yz85
This is my first time configiring a Cisco 1800 series router. As of now, computers cannot access the 192.168.1.0 network. I think the reason why it is not working correctly is nat and access lists. What I am trying to accomplish is the router is going to be a gate way between the 192.168.1.0 and 10.10.0.0. 192.168.1.0 is the internet and 10.10.0.0 is going to be the computers that are trying to access the resources on the other network. Your help is greatly appreciated.
Here is my config...
Building configuration...
Current configuration : 1144 bytes
version 12.4
hostname 1800
boot-start-marker
boot-end-marker
enable secret 5 $1$12zB$rKowCFLgjHFfx1i44X.Fn1
enable password xxxxxxx
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp pool DHCP
   network 10.10.0.0 255.255.255.0
   dns-server 8.8.8.8 4.2.2.2
   default-router 10.10.0.1
interface FastEthernet0/0
ip address 192.168.1.254 255.255.255.0
no ip route-cache
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
ip address 10.10.0.1 255.0.0.0
no ip route-cache
duplex auto
speed auto
interface Serial0/0/0
no ip address
no ip route-cache
shutdown
interface Serial0/1/0
no ip address
no ip route-cache
shutdown
ip classless
ip route 10.10.0.0 255.255.255.0 192.168.1.0
ip route 192.168.1.0 255.255.255.0 10.10.0.0
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password xxx
login
end
Thanks again. I really appreciate the help.
15 Replies 15
xr5054yz85
You were exactly right. You are awesome!!
Thanks so much for your help.
One last question, do you know of any resources that talk about say i have port 80 traffic and I want that to go out, but if I have port 21 traffic I want that to go over a differnt interface?
Thanks again soo much! You have been soo helpful, I cannot thank you enough!
