Cisco 1841 Config Help
xr5054yz85
This is my first time configiring a Cisco 1800 series router. As of now, computers cannot access the 192.168.1.0 network. I think the reason why it is not working correctly is nat and access lists. What I am trying to accomplish is the router is going to be a gate way between the 192.168.1.0 and 10.10.0.0. 192.168.1.0 is the internet and 10.10.0.0 is going to be the computers that are trying to access the resources on the other network. Your help is greatly appreciated.
Here is my config...
Building configuration...
Current configuration : 1144 bytes
version 12.4
hostname 1800
boot-start-marker
boot-end-marker
enable secret 5 $1$12zB$rKowCFLgjHFfx1i44X.Fn1
enable password xxxxxxx
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp pool DHCP
   network 10.10.0.0 255.255.255.0
   dns-server 8.8.8.8 4.2.2.2
   default-router 10.10.0.1
interface FastEthernet0/0
ip address 192.168.1.254 255.255.255.0
no ip route-cache
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
ip address 10.10.0.1 255.0.0.0
no ip route-cache
duplex auto
speed auto
interface Serial0/0/0
no ip address
no ip route-cache
shutdown
interface Serial0/1/0
no ip address
no ip route-cache
shutdown
ip classless
ip route 10.10.0.0 255.255.255.0 192.168.1.0
ip route 192.168.1.0 255.255.255.0 10.10.0.0
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password xxx
login
end
Thanks again. I really appreciate the help.
3 Accepted Solutions
The reason you are not able to communicate between 10.x.x.x and 192.168.1.x is because probably 192.168.1.x devices do not know how to reach 10.x.x.x. I am assuming that 192.168.1.x devices have their default gateway set to a different device. Please try the following:
ip nat outside
ip address 10.10.0.1 255.255.255.0
ip nat inside
access-list 1 permit 10.10.0.0 0.0.0.255
ip nat inside source list 1 interface FastEthernet0/0 overload
This should enable 10.x.x.x devices to initiate communication and get response back from 192.168.1.x devices.
Hope this helps.
NT
If you want to replace your current SOHO router with 1800 router, you can configure following parameters:
interface FastEthernet 0/0
ip address dhcp
ip nat outside
no shut
exit
interface FastEthernet 0/1
ip nat inside
no shut
exit
ip route 10.10.0.0 255.255.255.0 192.168.1.254
access-list 10 permit 10.10.0.0 0.0.0.255
access-list 10 permit 192.168.1.0 0.0.0.255
ip nat inside source list 1 interface FastEthernet 0/0 overload
If the DHCP Server (ISP) does not set the default gateway, then you need to get that specific information from them and enter that to the router.
ip route 0.0.0.0 0.0.0.0
Once the above are done on the new 1800 router, you can remove the NAT configuration on the inside router.
interface FasthEthernet 0/0
no ip nat outside
exit
no ip nat inside
exit
no ip nat inside source list 1 interface FastEthernet0/0 overload
no access-list 1 permit 10.10.0.0 0.0.0.255
Hope this helps.
NT
Can you please check to see if you have any firewall (Windows firewall, Antivirus) configured on the 10.10.0.2 machine? That could be the reason you are not able to ping that host.
NT
15 Replies 15
ian_banderaz
first of all, your dhcp netmask doesn't match with your interface address netmask. try to reconfigure it .
then try to change the ip route.  you didn't need to configure any ip route for directly connected network.
Thank you for your help, but unforunately that did not work. Also to add something that I did not say before, fastethernet0/0 is one network that is 192.168.1.0 and then fastethernet0/1 is the other network with dhcp that is 10.10.0.0. Maybe that was obvious, but just wanted to be clear.
Here is my new config.
Using 1058 out of 196600 bytes
version 12.4
hostname 1800
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
no ip routing
no ip cef
ip dhcp pool DHCP
no ip route-cache
speed auto
full-duplex
no mop enabled
no ip route-cache
duplex auto
speed auto
no ip address
no ip route-cache
shutdown
no ip address
no ip route-cache
shutdown
ip classless
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
Thanks again for your help. I really appreciate it. DHCP is working correctly.
Anyone able to help?
ip nat outside
ip nat inside
Hope this helps.
NT
Also, I did not see a default route set on the Router. You might want to set that if you are planning to go to internet from 10.x.x.x subnet.
NT
Ok, here is my config now, still will no luck. The router on the other end is a soho wrt600n (192.168.1.1)
version 12.4
hostname 1800
boot-start-marker
boot-end-marker
enable password xxx
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
no ip routing
no ip cef
ip dhcp pool DHCP
ip nat outside
no ip route-cache
speed auto
full-duplex
no mop enabled
ip nat inside
no ip route-cache
duplex auto
speed auto
no ip address
no ip route-cache
shutdown
no ip address
no ip route-cache
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
Thanks for your help in getting this solved. I really appreciate it, and if you have any other suggestions those would also be greatly appreciated. One thing that is a little weird is I can ping from he router to 192.168.1.1 but not from the router to 10.10.0.2 which is an xp computer on fastethernet0/1, but that computer has my tftp server and that works. I can ping from the xp computer to the router though. But still no internet or network resources from that xp computer. Also tried to ping from the xp machine to 192.168.1.1 with no responses.
Again thanks for your time.
Please execute the following command:
ip routing
This should enable routing and allow 10.x.x.x hosts to have outside access. If still did not work, please follow the steps below:
Once executed, then can you try to ping 4.2.2.2 from the Router and see if that works? If that does not, then the problem could be that the SOHO is blocking the access. In that case, please change the router's outside interface configuration so that the router gets IP through DHCP.
ip address dhcp
exit
Hope this helps.
NT
polofalltrades
I can't clearly visualize the topology. I assume that this looks like a point to point topology, am I correct? If yes, then please make sure that router A has routes for it to take clients to the other side. Same thing with router B. You should have a route that takes its internal clients to router A. Hope this helps. Maybe you could also post here the route that you defined for router B, so we can try to check it.
xr5054yz85
So the internet comes into the wan port of a WRT600n(192.168.1.1). Then one of the ports from the wrt600n switch goes to the 1841(192.168.1.254). Then I want to have a network that is 10.10.0.0 that can access the internet and network resources on the 192.168.1.0 subnet.
So I want the 1841 to act as a gateway between 10.10.0.0 and 192.168.1.0 I guess is what I am getting at.
Thanks for the help.
xr5054yz85
version 12.4
hostname 1800
boot-start-marker
boot-end-marker
enable password xxx
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip dhcp pool DHCP
ip ftp username Dan
ip ftp password xxxxx
ip nat outside
speed auto
full-duplex
no mop enabled
ip nat inside
duplex auto
speed auto
no ip address
shutdown
no ip address
shutdown
ip classless
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password xxx
login
end
The ip routing command fixed my issue. Here is my final config, maybe it will help someone else if they are having this issue.\
Now if you dont mind, I would like to add a variotion in just incase I need this. If I were to remove the wrt600n and put this another 1800 series router in its place I would need to change the interface ip's, the dhcp pool, the access list, but what would I need to change the ip route to? What would I need to add in to this router for the 192.168.1.0 network to also be able to access the resources on the 10.10.0.0 network?
Thanks for your help this far. I greatly appreciate it.
ip address dhcp
ip nat outside
no shut
exit
ip nat inside
no shut
exit
no ip nat outside
exit
no ip nat inside
exit
Hope this helps.
NT
xr5054yz85
Thanks for your help. I got the router configured as the default gateway. I am still going to try using the two routers together. I cannot take down the network right now, so I will report back later.
Again thanks for your help, talk to you soon!
Thanks for all the help.
So I am almost there. The one thing that I cannot do is ping from 192.168.1.0 to 10.10.0.2(xp computer). I can however ping 10.10.0.1 from 192.168.1.0  which is the XP computer. All the computers can reach the internet. I had to use a 1721 for the 10.10.0.0 beacuse that was all I had not in use. My apologies.
Here is the config for the 1841 that is acting as the default gaeway.
version 12.4
hostname 1800
boot-start-marker
boot-end-marker
enable password xx
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip dhcp pool DHCP
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip ftp username Dan
ip address dhcp
ip nat outside
speed auto
full-duplex
no mop enabled
ip nat inside
speed auto
half-duplex
no ip address
shutdown
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
ip nat inside source list 10 interface FastEthernet0/0 overload
control-plane
line con 0
line aux 0
line vty 0 4
password xxx
login
end
Here is the config for the 10.10.0.0 network (1721)
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname 1700
enable secret 5 $1$KcV7$wwTKv7hIN7.WHpmQc936m.
memory-size iomem 20
ip subnet-zero
ip dhcp pool DHCP
interface Ethernet0
ip nat outside
half-duplex
ip nat inside
speed auto
full-duplex
ip nat inside source list 1 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
password xxx
login
no scheduler allocate
end
Thanks again for your contiuned support.
NT
