Cisco 1841 DES/3DES encryption
network_user
       I have a new Cisco 1841 and when I do a sh ver it does not show me any licenses des/3des attached to it. I would like to know, how can I enable des/3des encryption on this router. I read that it has onboard des/3des encryption and I can enable it using an optional Cisco software. However I am not sure what software to use to enable the encryption. Could someone guide me through this?
Thank you.
2 Accepted Solutions
Haris P
Level 4
Level 4
Dear
As per the below link,the below encription support is there in the hardware by default . Im ruuning a  VPN with encription by using IOS image c1841-advipservicesk9-mz.124-16.bin
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016a59b.html
Encryption Support in Software and Hardware by Default
DES, 3DES, AES 128, AES 192, AES 256
regards
You need to have the following IOS or later on the router in order to enable crypto c1841-advsecurityk9-mz.124-24.T3.bin
Once you have the baove IOS then you can define the crypto policy in which you can mention the encryption algorithms like below...
crypto isakmp policy 14
encr 3des
authentication pre-share
group 2
Hope this clear you.
Please click on the correct answer if this answered your question.
Naidu.
Haris P
Level 4
Level 4
Dear
regards
encr 3des
group 2
Naidu.
network_user
Thanks Haris and Naidu. Your response was very helpful.
