Cisco 1841 Etherchannel
thomas-morgan
I have a Cisco 1841 that I'm trying to create an EtherChannel however it doesn’t appear to be accepting the commands (int p1, int fa0/0 -> Channel 1). The router is running IOS Version 15.1(4)M10. Is there some form of hardware limitation I am missing?
Carlos Villagran
Hello Thomas,
Yes, there is a hardware limitation. Firstly, the router needs a EtherSwitch module such as the NM-16ESW to support the port-channel feature.
In your case, the only supported etherswitch module for the 1841 ISR is the HWIC-4ESW and the port-channel feature is NOT supported in it, then it is not possible for a 1841 ISR to use a ether-channel.
Please check this link for reference:
http://www.cisco.com/c/en/us/products/collateral/routers/2600-series-multiservice-platforms/prod_qas0900aecd802a9470.html
Hope it helps, best regards!
JC
Carlos Villagran
Hello Thomas,
JC
Perfect, thank you very much.
