09-28-2016 12:01 AM - edited 03-08-2019 07:36 AM
hi,
we are using cisco 1841 router,recently i configured PPTP vpn in router.
vpn is working fine but no internet connection in LAN pc's
kindly help me on this
Abhijith
Solved! Go to Solution.
09-28-2016 02:05 AM
It is very clear no NAT on router for LAN subnet so no access to Public Internet.
Please add below config on router for interface PAT.
config t
access-list 1 permit 192.168.10.0 0.0.0.255
ip nat inside source list 1 interface FastEthernet0/0 overload
09-28-2016 12:42 AM
Have you done the NAT for LAN IPs? Please share config
09-28-2016 01:28 AM
Hi pawan,
Thanks for replay,
please see below configuration
Building configuration...
Current configuration : 1705 bytes
version 12.3
hostname CELERIX
boot-start-marker
boot-end-marker
enable secret 5 $1$9woY$eYCWJIUGDYv2OJ1KCQbyw.
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.10.2
ip dhcp pool mypool
network 192.168.10.0 255.255.255.0
dns-server 125.22.47.125 125.22.47.100
default-router 192.168.10.2
domain-name celerix.com
ip ips po max-events 100
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
no ftp-server write-enable
username anaik password 0
username praveen password 0
no crypto isakmp ccm
ip address 122.166.216.148 255.255.255.0
ip pim sparse-mode
ip nat outside
ip virtual-reassembly
speed 100
full-duplex
no cdp enable
interface FastEthernet0/1
ip address 192.168.10.2 255.255.255.0
ip pim sparse-mode
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clockrate 2000000
interface Virtual-Template1
ip unnumbered FastEthernet0/0
peer default ip address pool PPTP-Pool
no keepalive
ppp encrypt mppe 128
ppp authentication ms-chap ms-chap-v2
ip local pool PPTP-Pool 192.168.10.3 192.168.10.200
ip classless
ip route 0.0.0.0 0.0.0.0 122.166.216.1
no ip http server
no ip http secure-server
access-list 100 permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
password
login
end
09-28-2016 02:05 AM
config t
09-28-2016 02:45 AM
Thanks Pawan issue got resolved.
