Cisco 1841 router and Macbook pro problem
benjamin_a
I have this strange problem with my Macbook pro, when I connect it to my cisco 2940 8 port switch then I can reach my ISP (websites eg. google.com) in like 2 minuttes, then something is happening on my router, because suddenly I can´t reach my ISP
This is what I have found out so far:
1. when I lose connection to my ISP then I can only ping internal ip addresses eg. another computer in my network
2. if I renew my ip address on the Macbook then it works again in 2 minutts, then the same happens again.
This is my network setup:
Router -> Switch 1 -> Switch 2
I also know that it is not the Macbook, because it have got a new motherboard, and it have been reinstalled
also if I use the Macbook on a other network then it works fine.
All my other computers ( windows and linux ) works fine, no problems.
To me it looks like it is a Nat and/or DNS problem, but I can´t fine out what it is
If there is any one there have an idea what it is then pls tell
Best regard
Benjamin A
7 Replies 7
Reza Sharifi
Can you post the config from the router (sh run) and point out what interface connect to what network?
Also, are your switches just used as layer-2 devices?
Of course, here it is:
R1#sh run
Building configuration...
Current configuration : 2476 bytes
! No configuration change since last restart
version 12.4
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 xxxxx
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
resource policy
clock calendar-valid
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1
ip dhcp excluded-address 192.168.2.2
ip dhcp excluded-address 192.168.2.3
ip dhcp pool DHCP-SERVER-LAN-SIDE
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 192.162.153.164 194.239.134.83
   domain-name Net
ip ssh version 2
username xxx secret 5 xxx
username xxx password 0 xxx
interface FastEthernet0/0
ip address dhcp
ip nat outside
shutdown
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clockrate 2000000
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/1/0.1 point-to-point
description Link_To_Outside
ip address dhcp
ip nat outside
logging event subif-link-status
atm route-bridged ip
pvc 0/101
  oam-pvc manage
  encapsulation aal5snap
ip classless
no ip http server
no ip http secure-server
ip nat inside source list 1 interface ATM0/1/0.1 overload
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
banner motd ^C
                               C i s c o  S y s t e m s
                                Kun For Autoriserede!
  ------------------------------------------------------------ -------------- ^C
line con 0
exec-timeout 0 0
password xxx
logging synchronous
line aux 0
line vty 0 4
logging synchronous
transport preferred none
transport input ssh
end
This is how it is connected:
Router =
ATM0/1/0 -> ISP
FastEthernet0/1 -> Switch 1
the switches is just configureted as dum switches @layer 2, the only thing there is been changed on the is spanning tree portfast default.
Hope this helps
Have a look at this discussion and see if it is helpful to you.
https://supportforums.cisco.com/thread/2114266?start=0&tstart=0
Hi Benjamin,
Could you add the "ip route 0.0.0.0 0.0.0.0 dhcp" command and try again?
benjamin_a
Hi again
I have now tryed the "ip route 0.0.0.0 0.0.0.0 dhcp", but it didn´t help
I have also read the discussion that you (Reza Sharifi) recommended, but is it not over wifi the problem is
At this point I am lost of idea what it can be, but one thing I found out was that if the Macbook is the only pc on the network, then it works fine ??
Is there how that I can degbu on the router ? I have tryed the degug all, but then my router crashed
I think that I have found the problem !
it seems to be the switch 2, I have tested it this way:
1. connected the Macbook to the switch 1 and there was no problem !
2. replaced the switch 2 with at dum cheap D-Link (yes I know it is D-Link )  switch and now it is working, and it have been working the last hours
I will test it to tomorrow, and if it is the switch then
what can be wrong with my cisco 2940 switch ?
would it be better if I make a new post ?
Thanks for update Ben. If you found the problem, than stay away from the 2940 switch.  It could be an IOS bug.  Since you are not using it, you can clear the config and load a newer version of IOS and test again.  No need for a new post.
