Cisco 1841 router Auxiliary port connect to Modem
admin_2
Level 3
Level 3
Can I use the following cable and adaptor for connecting the aux port of cisco 1841 ro Modem
1) a flat-satin rolled RJ-45--RJ-45 cable (part number CAB-500RJ= )
2) an RJ-45 to DB-25 adapter marked "MODEM" (part number CAB-25AS-MMOD)
vijayasankar
Level 4
Level 4
Yes. That's correct.
Refer to the URL below.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094bbc.shtml
Hope this helps.
-VJ
Not applicable
Thank you very much, VJ
I have checked the document. However, it is not mentioned the cisco 1841, so I would like to confirm if it is work in the router.
Cheer
