Connecting Cisco Switches (Basic Question)
muca
Level 3
Level 3
If I want to connect 2 2950 switches I use a twisted-pair cross-over cable, right?
But if I want to connect 2 2950 T through 1000 uplink ports what kind of cable do I use? Cross or straight-through cable?
adnan.zafar
When u connect any Cisco Switche to each other you mus use cross cables so whatever it C2950-24 or C2950-24T they will connect to each other with Cross cables
devang_etcom
Level 7
Level 7
yes to connect two switches you need cross cable....
you can also use the straight cable to connect the two switches but for that they should support the "AUTO MDIX"
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_installation_guide_chapter09186a00807b5a39.html
regards
Devang
devang_etcom
Level 7
Level 7
here is the link which include the cable specifications also...
http://www.cisco.com/en/US/products/hw/switches/ps628/products_installation_guide_chapter09186a00801cd6d3.html#40332
rate the post if it helps
regards
Devang
adnan.zafar
pramod.prasad
hi,
To connect two switches you need cross cable
