cisco 1900 IP address add in Configuring Interface Card and Module
sujeetprajapati
Dear Team Facing the Issue in cisco router when ip add in interface found the Issue % IP addresses may not be configured on L2 links
Router#show ip interface brief
Embedded-Service-Engine0/0 unassigned YES unset administratively down down
GigabitEthernet0/0 unassigned YES unset administratively down down
GigabitEthernet0/1 unassigned YES unset administratively down down
Serial0/0/0 unassigned YES unset administratively down down
GigabitEthernet0/1/0 unassigned YES unset down down
GigabitEthernet0/1/1 unassigned YES unset down down
GigabitEthernet0/1/2 unassigned YES unset down down
GigabitEthernet0/1/3 unassigned YES unset down down
Vlan1 unassigned YES unset down down
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#itn
Router(config)#itngi
Router(config)#int
Router(config)#do show vlan-switch
VLAN Name Status Ports
1 default active Gi0/1/0, Gi0/1/1, Gi0/1/2
Gi0/1/3
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 1002 1003
1002 fddi 101002 1500 - - - - - 1 1003
1003 tr 101003 1500 1005 0 - - srb 1 1002
1004 fdnet 101004 1500 - - 1 ibm - 0 0
1005 trnet 101005 1500 - - 1 ibm - 0 0
Router(config)#int gi0/1/0
Router(config-if)#ip add 192.168.15.2 255.255.255.0
% IP addresses may not be configured on L2 links.
9 Replies 9
Mark Elsen
  - Try the "no switchport" command first on the interface ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Already used this command but still not working there
Please see this
Router(config)#interface gigabitEthernet 0/1/0
Router(config-if)#no swi
Router(config-if)#no switchport
% Incomplete command.
Router(config-if)#
sujeetprajapati
This is Device# PID SN
*0 CISCO1905/K9 FGL212092XS
Router# show vlan-switch
Gi0/1/3
1005 trnet 101005 1500 - - 1 ibm - 0 0,
kindly Suggest
 @sujeetprajapati - For a router ; you need to  create a VLAN, assign an ip address to it , and then put your interface in that VLAN
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Hi Marce1000
as Instruction after that put the command , but still not ping to my pc
my pc ip address 192.168.119.6
Router#show ip int b
GigabitEthernet0/1/3 unassigned YES unset up up
Vlan1 unassigned YES manual down down
Vlan10 192.168.119.1 YES manual up up
Router#show vl
Router#show vlan?
vlan-range vlan-switch vlans
Router#show vlans
No Virtual LANs configured.
Router#show vlan-s
Router#show vlan-switch
10 VLAN0010 active Gi0/1/3
10 enet 100010 1500 - - - - - 0 0
Router#
Router#ping 192.168.119.6
Sending 5, 100-byte ICMP Echos to 192.168.119.6, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#
yet not resolved
If the port is layer2, and PC connected, check do you see MAC address on the port for the troubleshoot. also check IP arp table.
from PC are you able to ping the Gateway ?
check PC has any firewalls ? (disable and test it)
BB
@balaji.bandi  I am already check also this firewall but still not ping to gateway
Router#show ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.119.1 - 0027.e3d3.32a0 ARPA Vlan10
Internet 192.168.119.6 1 b07b.251d.56a5 ARPA Vlan10
Router#
any other
we can see the IP arp that means good from network side and also you see mac address.
now from PC are you able to ping local IP that is 192.168.119.6 - yes ?
can you post ipconfig from PC ?
from router are you able to ping 192.168.119.1 ? (self ping ?)
BB
 @sujeetprajapati   >...as Instruction after that put the command
                          Which command , please show me what you configured ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
