cisco 1900 switch Trunk capability with WS-C3560G-24PS
srikanth ath
Level 4
Level 4
Hello Expert,
In our production.
The switch interface of 3560 connected to 1900 is configured as access port. and i was asked to make the both the interfaces of 1900 and 3560 as trunk. can i configure as some where i read the switch 1900 doesnt support 802.1q.
Switch 3560 seems to be supported with ISL and .1q
X(config)#int gigabitEthernet 0/27
X(config-if)#switchport trunk en
X(config-if)#switchport trunk encapsulation ?
  dot1q      Interface uses only 802.1q trunking encapsulation when trunking
  isl        Interface uses only ISL trunking encapsulation when trunking
  negotiate  Device will negotiate trunking encapsulation with peer on
             interface
If i can i have a document with CLI configuration as this 1900 switch looks weird and im going crazy in understanding the configs.
10 Replies 10
Jon Marshall
The 1900 switch only supports ISL on trunk links as you say.
Here is a link to a document showing how to configure a 1900 connecting to a CatOS switch. Ignore the CatOS switch part -
http://www.cisco.com/c/en/us/support/docs/lan-switching/inter-switch-link-isl/24066-174.html
Jon
Thanks for the responses. I went through the Document, but the Switch 1900 doesnt have the Trunk configuration under the interface.
It just has
X(Config)# Int e 0/1
X(Config-if)#vlan-membership ?
static
dynamic
X# trun?
<cr>
Cisco1912#show trunk ?
A Trunk A
B Trunk B
Cisco1912#show trunk A
Do you have the Enterprise Edition software ?
Jon
Thanks Jon.
I see it is the Enterprise edition software under sh version.
The Fast ethernets port are trunkable in this switch the rest of the eth 0/1 to 0/24 are not.
but i have no idea on how to trunk this 1900 with 3560 .
The 1900 has these options on, auto, desirable. what option to be selected and respective mode i need to select on the trunk interface of 3560?
1900#sh version
Cisco Catalyst 1900/2820 Enterprise Edition Software
Version V8.00.04
Copyright (c) Cisco Systems, Inc.  1993-1998
1900(config)#int fa 0/26
1900(config-if)#trun
1900(config-if)#trunk?
trunk  trunk-vlan
1900(config-if)#trunk ?
  auto         Set DISL state to AUTO
  desirable    Set DISL state to DESIRABLE
  nonegotiate  Set DISL state to NONEGOTIATE
  off          Set DISL state to OFF
  on           Set DISL state to ON
Ok thanks all.
the last thng left to be clarified.
what does trunk on / desirable / auto means in 1900 switches.
Not sure if you saw my last relpy
On the 1900
int f0/26
trunk on
On the 3560
int f0/24
switchport trunk encap isl
switchport mode trunk
In answer to your trunk status quey
ON = No negotiation - this prt does not send DTP packets IT IS ALWAYS a TRUNK
DISIABLE = The port initiates DTP and will become trunk if the other end responds, if the other end does not respond the port becomes an access port
AUTO = Like the desrirable BUT the port will not initiate the DTP negotiation, it will only respond.
AUTO to AUTO == NO TRUNK
DESIRABLE to AUTO == TRUNK
DESIRABLE to DESIRABLE == TRUNK
ON to ON == TRUNK
ON to AUTO -- TRUNK
ON to DESIRABLE == TRUNK
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
Jan Rolny
Level 3
Level 3
please note that you need Enterprise Edition software
  • All Ethernet ports support ISL encapsulation. Enterprise Edition software is necessary.
  • There is no support for 802.1Q.
  • There is support for DTP in ISL only
Best resgards,
Jan
srikanth ath
Level 4
Level 4
It just has
static
dynamic
X# trun?
<cr>
A Trunk A
B Trunk B
srikanth ath
Level 4
Level 4
It just has
static
dynamic
X# trun?
<cr>
A Trunk A
B Trunk B
On the 1900
int f0/26
trunk on
On the 3560
int f0/24
Hope this helps
Alex
