Cisco 1901 Wireless setup
sugaranderson1
Community Member
I hope you can help me with my question below and shed some light.
we had this cisco router 1901 in one of our remote office and the management wants to configure 4 wireless pc's
to only talk to each other for security reasons.
1. is this possible to do in wireless? i know in VLAN this can be done by assigning pc's in port in a switch.
2. if possible, kindly give an idea on how to implement this setup
thank you in advance!
sugar
Jeff Van Houten
Level 11
Level 11
If the devices are close enough you can setup a peer to peer wireless network and not worry about a wap at all.
Jeff Van Houten
Level 11
Level 11
hello,
thanks for your reply! yes, you are correct a peer to peer will do.
i just forgot the basic.
again, thanks for your help.
sugar
