Cisco 1905 not booting from flash
Not applicable
Hi experts,
I am trying to configure a 1905, but the router boots into readonly rommon after configuring the router and  copy running config  to startup config,  then, boots router gone to the rommon mode.
Below is the out put of in the rommonitormode.
Total memory size = 256 MB
CISCO1905/K9 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC disabled
Readonly ROMMON initialized
program load complete, entry point: 0x80903000, size: 0x4c4a0
open(): Open Error = -1
boot: cannot open "usbflash1:"
boot: cannot determine first executable file name ondevice "usbflash1:"
System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 2012 by cisco Systems, Inc.
loadprog: error - on load of image from file system with monlib
boot: cannot load "usbflash0:"
rommon 1 >
rommon 1 > dir usbflash0:
Directory of usbflash0:
2 75551300 -rw- c1900-universalk9-mz.SPA.154-3.M2.bin
18448 476247 -rw- crashinfo_20170728-114759-UTC
18565 0 drw- call-home
rommon 2 >
rommon 2 >
rommon 2 > boot usbflash0:c1900-universalk9-mz.SPA.154-3.M2.bin
boot: cannot load "usbflash0:c1900-universalk9-mz.SPA.154-3.M2.bin"
rommon 3 > dir usbflash1:
Directory of usbflash1:
3 55111032 -rw- c1900-universalk9-mz.SPA.151-4.M5.bin
rommon 4 > boot usbflash1:c1900-universalk9-mz.SPA.151-4.M5.bin
usbflash1: not present
rommon 5 >
Please help me to solve this issue.
regards,
Rajesh Mane
Mark Malone
Can you not boot from internal flash instead of USB ? it looks like its having an issue reading it , maybe the format that the USB is in is incorrect , what format is it currently set to ?
Leo Laohoo
The USB flash is "shorting".  The pins are not contacting each other.  The moulding of the USB flash itself is preventing this.  Get a file and shave off the moulding or try a different variety of USB flash.
Try one of this (image below).  Maximum size 16 Gb.
