Cisco 1941 > BT homehub
robjdarby1
I am trying to test a Cisco 1941on my home network (to prepare for a site connection to a BTNet NTE) ...
I have routing working fine for the internal VLANs but and can ping everything (including the Internet) from the router console, but cannot ping from any client connected to any VLAN to the Internet.
The setup is basically >
Int gi0/0 connected to the Homehub
Int gi0/0/0 connected to the PC (the pc has an IP of 10.23.4.40). Interestingly when I try and ping to say www.google.co.uk it resolves the ip via DNS ok, but no replies. No internet either via IE.
Here is my fairly basic running-config >
_____________________________________________________________________
CORE-RT1# sh run
Building configuration...
*Sep 21 20:14:08.403: %SYS-5-CONFIG_I: Configured from console by admin on console
Current configuration : 4169 bytes
! Last configuration change at 20:14:08 UTC Sun Sep 21 2014 by admin
version 15.2
hostname CORE-RT1
boot-start-marker
boot-end-marker
enable secret 4 3cAj.f2PkssJmkRu4YUQUCCy3vPEtMp3aQDdde3hiFU
no aaa new-model
no ip source-route
ip cef
ip dhcp excluded-address 10.23.3.1 10.23.3.39
ip dhcp excluded-address 10.23.4.1 10.23.4.39
ip dhcp excluded-address 10.23.1.1 10.23.1.150
ip dhcp excluded-address 10.23.2.1 10.23.2.39
ip dhcp pool USERS
 import all
 network 10.23.3.0 255.255.255.0
 default-router 10.23.3.1
ip dhcp pool DATA
 import all
 network 10.23.4.0 255.255.255.0
 default-router 10.23.4.1
 dns-server 192.168.1.254
ip dhcp pool MGMT
 import all
 network 10.23.1.0 255.255.255.0
 default-router 10.23.1.1
ip dhcp pool CCTV
 import all
 network 10.23.2.0 255.255.255.0
 default-router 10.23.2.1
ip domain name XXXXXXX
ip name-server 192.168.1.254
no ipv6 cef
crypto pki trustpoint TP-self-signed-1284061912
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1284061912
 revocation-check none
 rsakeypair TP-self-signed-1284061912
crypto pki certificate chain TP-self-signed-1284061912
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323834 30363139 3132301E 170D3134 30393231 31363330
  31315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32383430
  36313931 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81008ADD 2D46064A 356B70C8 C8EFA1D7 B22C11A8 950680CF 68DF335A 7A19B982
  7080913D C5C0776E 93B9579A B1776B26 864DF529 83C88225 08B92EFA B29ED9C7
  48026077 5C25C5EE 6B924F6B 366E0478 B74A694D 6885EE66 8CF01774 0869B393
  0E618221 1CB081DB AE0A5ADB 6536A95D E64E4D07 E63324D0 C2CF3CA9 5F28D3BC
  A7490203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1437E42E B1BD86C7 94D9B99C 5D7C5498 D585D5B5 8D301D06
  03551D0E 04160414 37E42EB1 BD86C794 D9B99C5D 7C5498D5 85D5B58D 300D0609
  2A864886 F70D0101 05050003 8181002A D6DF1CB9 FEB18E09 93B57980 5A36FEE8
  D9F84CF6 EE331D77 46C92D8C 36D014CB 00A23CB8 33E1932E 55D5E518 D40B1694
  F0D7B511 CFD1A40B BBCD42BC 09EA183F EBABF39C 4FD3257B 6092C79A 1C2E3DE3
  583BFAB1 87B18EFF 80317E8D 7BA8E766 C0A46751 6ECCB6EA 94082138 7A614F43
  3681C2EC 8257257C E0E95335 2A1833
        quit
license udi pid CISCO1941/K9 sn FCZ1812C2MY
username XXXXXX password 0 XXXXXXX
ip ssh version 2
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.1.138 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0/0
 switchport access vlan 40
 no ip address
interface GigabitEthernet0/0/1
 no ip address
interface GigabitEthernet0/0/2
 no ip address
interface GigabitEthernet0/0/3
 no ip address
interface Vlan1
 description Management
 ip address 10.23.1.1 255.255.255.0
interface Vlan20
 description CCTV
 ip address 10.23.2.1 255.255.255.0
interface Vlan30
 description Phones
 ip address 10.23.3.1 255.255.255.0
interface Vlan40
 description Data and users
 ip address 10.23.4.1 255.255.255.0
 ip nat inside
router rip
 redistribute connected
 network 10.0.0.0
 network 192.168.1.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat pool out 192.168.1.138 192.168.1.138 prefix-length 24
ip route 0.0.0.0 0.0.0.0 192.168.1.254
control-plane
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login local
 transport input ssh
scheduler allocate 20000 1000
end
Also here is the output from show ip route >
CORE-RT1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 192.168.1.254 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.1.254
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.23.4.0/24 is directly connected, Vlan40
L        10.23.4.1/32 is directly connected, Vlan40
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, GigabitEthernet0/0
L        192.168.1.138/32 is directly connected, GigabitEthernet0/0
many thanks in advance
Rob
Add a route on your internet router
ip route10.23.0.0 255.255.0.0 192.168.1.138
20 Replies 20
vishal vyas
Please add following command
# ip routing
Hi vishalvyas1986
I have typed that command about 50 times ..... it never appears in the sh run
Any thoughts please?
Try to type ip routing and then hit (?) and please let me know what you see.
Could you please send me the output of following command
# ping 4.2.2.2 source 192.168.1.138
# ping 4.2.2.2 source 10.23.4.1
ip routing ?
protocol     IP Routing Protocol
<cr>
Results - ping 4.2.2.2 source 192.168.1.138
100% success
0 % success
thanks!
please send me following output
# show vlan
# show ip int b
After seeing your config, I think your ISP is doing NATing, so you don't need to do NATing on your side. You can remove the NAT statement from both the interface.
 if you don't see any vlan other then vlan 1 in your # show vlan out put, then you need to create a L2 vlans
vlan 40
name XXXX
vlan 20
name xxxx
vlan 30
name xxxxx
Output as requested >
CORE-RT1#show ip int b
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         192.168.1.138   YES DHCP   up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/0       unassigned      YES unset  down                  down
GigabitEthernet0/0/1       unassigned      YES unset  down                  down
GigabitEthernet0/0/2       unassigned      YES unset  down                  down
GigabitEthernet0/0/3       unassigned      YES unset  down                  down
Vlan1                      10.23.1.1       YES NVRAM  down                  down
Vlan20                     10.23.2.1       YES NVRAM  down                  down
Vlan30                     10.23.3.1       YES NVRAM  down                  down
Vlan40                     10.23.4.1       YES NVRAM  down                  down
CORE-RT1#show vlan
% Ambiguous command:  "show vlan"
CORE-RT1#show vlans
No Virtual LANs configured.
vishalvyas1986 FYI
I have DHCP and intervlan routing working fine.
A client on VLAN 40 can ping a client on VLAN 1 etc ... just none of them can ping the internet router (192.168.1.254) or the access the internet
thanks
Rob
If you see above output, all the vlans are down, so you need to crate a L2 vlans as below.
vlan 40
name XXXX
exit
Once you do that, vlan 40 will show up as ( up up ), and you should able to ping the internet
Ok, i type the following:
conf t
vlan 40
name DATA
exit
exit
show vlans
*** No Virtual LANs configured. ***
Odd ???
Thoughts please?
Rob
There are some different commands when you use EHWIC card in 1941, so please do following
# show vlan?
# show vlan ?
It will give you all the possible options.
Please also send me the output of
# show ip int b
Most probably it is
# show vlan-switch
CORE-RT1#show vlan-switch
VLAN Name                             Status    Ports
1    default                          active    Gi0/0/1, Gi0/0/3
20   CCTV                             active
30   PHONES                           active
40   DATA                             active    Gi0/0/0, Gi0/0/2
99   VLAN0099                         active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
20   enet  100020     1500  -      -      -        -    -        0      0
30   enet  100030     1500  -      -      -        -    -        0      0
40   enet  100040     1500  -      -      -        -    -        0      0
99   enet  100099     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
CORE-RT1#
Please see my above comment
Laptop got a good DHCP address from router for VLan40
ip   10.23.1.40
router 10.23.4.1
Can ping the 1941 router (192.168.1.138), but not the internet router (192.168.1.254)
Rob
