cisco 1941 problem getting out to internet.PLEASE HELP!!!
diaspora21
Dear sirs,
I have some problems getting out to internet from my vlan. the configuration is this:
I have 2 Vlan 192.168.1.0 and 172.16.1.0 .
The problem is that when I am on subnet 192 and i use default gateway 192.168.1.1 I can access internet .. when I am on 172 subnet with gateway 172.16.1.1 I can't acces internet. I can ping 172.16.1.1 but I can't go out .. Here is my configuration :
Building configuration...
Current configuration : 4188 bytes
! Last configuration change at 01:01:22 UTC Sat Oct 9 2010
version 15.0
service password-encryption
hostname xxxxxxxxxxxx
boot-start-marker
boot-end-marker
enable password xxxxxxxxx
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp pool internal
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 192.168.1.20
   domain-name xxxxxxxx
   lease 7
interface GigabitEthernet0/0
no ip address
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/0.172
encapsulation dot1Q 172
ip address 172.16.1.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.192
encapsulation dot1Q 192
ip nat inside
interface GigabitEthernet0/1
description outside
ip address xxxxxxxxxxxx 255.255.255.248
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 192.168.1.20 xxxxxxxxxxxx 25 extendable
ip nat inside source static tcp 192.168.1.20 xxxxxxxxxxxx  53 extendable
ip nat inside source static tcp 192.168.1.20 xxxxxxxxxxxx  80 extendable
ip nat inside source static tcp 192.168.1.20 xxxxxxxxxxxx  110 extendable
ip nat inside source static tcp 192.168.1.20 xxxxxxxxxxxx  143 extendable
ip nat inside source static tcp 192.168.1.20 xxxxxxxxxxxx  443 extendable
ip nat inside source static udp 192.168.1.20 xxxxxxxxxxxx  500 extendable
ip nat inside source static tcp 192.168.1.20 xxxxxxxxxxxx  993 extendable
ip nat inside source static udp 192.168.1.20 xxxxxxxxxxxx  995 extendable
ip nat inside source static tcp 192.168.1.11 80 xxxxxxxxxxxx  80 extendable
ip nat inside source static tcp 192.168.1.12 53 xxxxxxxxxxxx  53 extendable
ip nat inside source static tcp 192.168.1.12 80 xxxxxxxxxxxx  80 extendable
ip nat inside source static tcp 192.168.1.12 110 xxxxxxxxxxxx  110 extendable
ip nat inside source static tcp 192.168.1.12 143 xxxxxxxxxxxx  143 extendable
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
password 7 xxxxxxxxxxxx
login
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Please help
andtoth
Level 4
Level 4
Looks like you need to specify the 172.16.1.0 subnet in access-list 1 in the same way as 192.168.1.0 in order for the router to know that it needs to translate the source IP address of packets when they have a source from 172.16.1.0 range.
The access-list lines should look like this:
access-list 1 permit 172.16.1.0 0.0.0.255
Andras
andtoth
Level 4
Level 4
Andras
Thank you very much Andras..!!
