Cisco 200 Micro Webserver HardDrive problem
ewf_cirda
Hi everyone, i've recently got a Cisco 200 Micro Webserver without any software , and no CDROM...
The problem is that the SCSI Harddrive wasn't formatted and i don't know which filesystem to use on this disk...
I get a lot of errors about /local , i've tried quick-erase,long-erase, and makefs , but none of these worked.
This is some console output:
Failed to create /local/etc directory
failed to create tftpboot dir: /local/tftpboot
Could not add acl entry for /local/cisco/mw200/website/logging_in.html
Could not add acl entry for /local/cisco/mw200/website/wizards.html
Could not add acl entry for /local/cisco/mw200/applets
Could not add acl entry for /local/var
Could not add acl entry for /local/var/tmp
Could not add acl entry for /local/var/log
Could not add acl entry for /local/etc
Could not add acl entry for /local/tftpboot
Could not add acl entry for /local/lib
fopen: errno = 0xd0001
httpd: could not open error log file /local/var/log/error.log.
Syslogdopen: can't open/crerrno = 0xd0001
eatehttpd: could not ope log file. Access logfile /local/var/log/access.log.
my-web#sync /local
Opening device /local
Could not open root dir on device
my-web#makefs /local
dosFsMkfs: dosvc_secPerClust = 16
dosFsVolInit: pBlkDev->bd_bytesPerBlk 512
dosFsMkfs: dosFsVolInit failed
dosFsVolCheck: DOS_VD_READY_CHANGED
dosFsVolCheck: DOS_VD_RESET
did iosDevDelete of /local
uvfatMakeFs: Could not make the file system for device /local
Operation failed
my-web#long-erase /local
Long-Erase the entire disk?[no]: yes
Unmounting filesystem (if any) on device /local
Bad device name.
Long-Erasing device /local
my-web#quick-erase /local
Quick-Erase the entire disk?[no]: yes
Bad device name.
Quick-Erasing device /local
mweb200#show interface scsi 0
ID LUN VendorID ProductID Rev. Type Blocks BlkSize pScsiPhysDev
1 0 IBM S60B 0 4096 512 0x001d56b0
SCSI current device status:
SCSI device ID1: NOT ACTIVE
SCSI transaction statistics:
SCSI Selection Good: 142
SCSI Selection Timeout: 0
SCSI Sync Nego Good: 0
SCSI Sync Nego Bad: 0
SCSI Resets: 0
SCSI DataIn Timeout: 0
SCSI DataOut Timeout: 0
ewf_cirda
Does anyone know ?
