01-14-2008 01:13 PM - edited 03-05-2019 08:28 PM
This is my first router configuration. I am having problems with 192.168.50.0/24 network getting to other networks (192.168.51.0/24)
Solved! Go to Solution.
01-14-2008 01:43 PM
Welcome :)
Please mark the conversation as solved if the posts resolve your issue.
Best Regards,
Mounir Mohamed
01-14-2008 01:19 PM
can I ask why you are nat'ing? also do you have a device on the two separate networks and do they have the correct subnet mask on them? if you do a traceroute from one device to the other what is the result?
01-14-2008 01:23 PM
This due to wrong Wildcard bits, use the below ACL format to allow directlly connected subnet to overloaded by F0/0 ip address, the ACL you used only allow any ip address ended by 0 which is not valid address in your case, so you can correct it by use this format:
access-list 7 permit 192.168.50.0 0.0.0.255
Pls rate helpful posts.
Best Regards,
Mounir Mohamed
01-14-2008 01:35 PM
Thanks, mounir.mohamed
That did the trick... it works now.
01-14-2008 01:43 PM
Welcome :)
Best Regards,
Mounir Mohamed
