Cisco 2611XM syslog errors
Hello, I am getting these types of errors on a 2611XM router. Anyone got a clue?
dis-xak#sh log
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 4812 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 8 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: level debugging, 4812 messages logged, xml disabled,
                    filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Trap logging: level notifications, 1051 message lines logged
        Logging to 192.168.10.2, 1051 message lines logged, xml disabled,
               filtering disabled
Log Buffer (100000 bytes):
2y1w: rsa_create_handler: Invalid AVL (0x5ED3F88, 0x5ED3F90, 0x5ED3F98, 0x5ED3FA0, 0x5ED3FA8, 0x5ED3FB0, 0x5ED3FB8, 0x0)
2y1w: IPSECcard: an error coming back 0x007F
.Jun  7 03:32:11: %SSH-3-KEYPAIR: Attempt to generate server keys failed - error code: hardware error
-Process= "SSH Event handler", ipl= 0, pid= 3
-Traceback= 8085F7C8 8156F154 8059C338 8059F75C
.Jun  7 03:32:11: %SSH-5-DISABLED: SSH 2.0 has been disabled
.Jun  7 04:20:37: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 10.0.0.11
.Jun  7 05:58:29: %SYS-5-CONFIG_I: Configured from console by lgcomsupport on vty1 (192.168.0.108)
.Jun  7 06:00:19: %SSH-5-ENABLED: SSH 2.0 has been enabled
.Jun  7 06:00:21: %SYS-5-CONFIG_I: Configured from console by lgcomsupport on vty1 (192.168.0.108)
.Jun  7 06:03:07: %SYS-5-CONFIG_I: Configured from console by lgcomsupport on vty1 (192.168.0.108)
.Jun  7 09:03:52: %CLEAR-5-COUNTERS: Clear counter on interface Serial0/0 by lgcomsupport on vty1 (192.168.0.184)
.Jun  7 09:09:31: %SYS-5-CONFIG_I: Configured from console by lgcomsupport on vty0 (192.168.0.108)
.Jun  7 09:10:24: %SYS-5-CONFIG_I: Configured from console by lgcomsupport on vty0 (192.168.0.108)
.Jun  7 09:13:04: %SYS-5-CONFIG_I: Configured from console by lgcomsupport on vty0 (192.168.0.108)
.Jun  7 09:15:02: %SYS-5-CONFIG_I: Configured from console by lgcomsupport on vty0 (192.168.0.108)
.Jun  7 09:28:23: %SYS-5-CONFIG_I: Configured from console by lgcomsupport on vty0 (192.168.0.108)
2y1w: rsa_create_handler: Invalid AVL (0x5ED2D08, 0x5ED2D10, 0x5ED2D18, 0x5ED2D20, 0x5ED2D28, 0x0, 0x5ED2D38, 0x5ED2D40)
.Jun  7 20:00:26: %SSH-3-KEYPAIR: Attempt to generate server keys failed - error code: hardware error
.Jun  7 20:00:26: %SSH-5-DISABLED: SSH 2.0 has been disabled
.Jun  8 02:20:38: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 10.0.0.11
dis-xak#sh ver
Cisco IOS Software, C2600 Software (C2600-ADVSECURITYK9-M), Version 12.3(11)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Sat 18-Sep-04 11:38 by eaarmas
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
dis-xak uptime is 2 years, 1 week, 5 days, 3 hours, 14 minutes
System restarted at 12:32:45 EEST Wed May 27 2009
System image file is "flash:c2600-advsecurityk9-mz.123-11.T.bin"
Cisco 2611XM (MPC860P) processor (revision 0x100) with 94450K/3854K bytes of memory.
Processor board ID JAE071800DF (3191415314)
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
2 Serial interfaces
1 Virtual Private Network (VPN) Module
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
TIA, Nicos Nicolaides
cadet alain
You probably have a hardware problem with your VPN module.
Regards.
Alain.
cadet alain
Regards.
Alain.
