10-15-2017
05:56 PM
- last edited on
03-25-2019
04:45 PM
by
ciscomoderator
Hi expert,
Recently I'm received new set HIPOT HypotULTRA 7804 but Cisco 2800 not able communicate,
so I set baud rate to 38400 in cisco 2800 but still no respond from console line 67 to HypotULTRA 7804 .
Can someone advice?
jabp2wgbi12-term2#conf t
Enter configuration commands, one per line. End with CNTL/Z.
jabp2wgbi12-term2(config)#line 67
jabp2wgbi12-term2(config-line)#speed 38400
jabp2wgbi12-term2(config-line)#end
jabp2wgbi12-term2#
jabp2wgbi12-term2#sh line
Tty Line Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 0 CTY - - - - - 0 0 0/0 -
1 1 AUX 9600/9600 - DTR-Act - - - 0 0 0/0 -
* 1/0 66 TTY 9600/9600 - DTR-Act - - - 58 0 0/0 -
* 1/1 67 TTY 38400/38400 - DTR-Act - - - 10 0 0/0 -
* 1/2 68 TTY 9600/9600 - DTR-Act - - - 9 0 0/0 -
10-15-2017 07:29 PM
Hi Expert,
Just to top up that Current setting of Cisco 2800 is working fine to communicate with Hipot Omnia 8104. But I received new model Hipot HypotULTRA 7804 and console of Cisco 2800 not able to be detected, I checked the RS-232 interface of 2 unit Hipot model is the same and the difference is only the baud rate - Omnia 8104(9600 baud) / HypotULTRA 7804(38400 baud).
Can someone explain/ advice this issue.. thanks
Attached is the setting of Cisco 2800.
Omnia 8104
communication port configuration
9600 baud
8 data bits
1 stop bit
No parity
HypotULTRA 7804
38400 baud
8 data bits
1 stop bit
No parity
