Cisco 2800, which network module ?
alain_richard
Frequent Visitor
Frequent Visitor
I would like to be able to use a port of the network module like a port on the router itself. Specifically, I need to :
use the port as a real router port (issue something like "interface fastethernet0/5 no switchport") subneting the interface to access to each VLAN presented on this port.
As far as I have understood, this is not possible with a HWIC-4ES module as it doesn't enable to use the port as router ports.
It seams I can make router ports from a NM-16ESW module, but I don't know if I can then subinterface it in order to get my VLANs. I know it is possible using SVI, but then I am restricted to 32 VLANs, too restrictive for me.
The NME-16ES-1G service module seams to be less restrictive. Is it the solution for me ? Do the base IP IOS is sufficient for what I need (on the routeur I will run an IOS Advanced IP Services) ?
Alain
nethelper
Level 6
Level 6
Bonsoir,
unfortunately, the routed ports on the EtherSwitch module do not support subinterfaces.
The following modules all support 1024 VLANs, so that would be a good option:
NME-16ES-1G-P
NME-X-23ES-1G-P
NME-XD-48ES-2S-P
NME-XD-24ES-1S-P
Saluts,
Nethelper
