Cisco 2801 and Vlans
windieana
Dear all, i'd like your help on the following issue:
I've a cisco 2801, with 2 fa interfaces and 1 wic-4esw module.
I want to have an access to internet using fa 0/1 (no problem); and i need to provide internet to 2 private lans. I want to use the wic-4esw ports to access these 2 privates lans (2 ports for each lan).
Until now, i was able to define 2 vlans in vlan database. Also i could assigned 2 ip addresses to 2 fa 0/0.1 and fa 0/0.2, and use "encap dot1Q" on both interfaces.
But the router doesn't accept "switchport ..." on each interface and also doesn't accept "interface Vlan vlan_num", like is referenced in
"http://cisco.com/en/US/docs/routers/access/1700/1711/software/feature/guide/1711swm.html#wp228931"
Could you help? I'don't know what to do.
Thanks in advance
IOS info
Cisco IOS Software, 2801 Software (C2801-IPBASE-M), Version 12.4(1c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 26-Oct-05 08:42 by evmiller
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
SugarDaddy uptime is 3 days, 4 hours, 23 minutes
System returned to ROM by reload at 17:24:53 UTC Fri Nov 30 2007
System image file is "flash:c2801-ipbase-mz.124-1c.bin"
9 Replies 9
JORGE RODRIGUEZ
Level 10
Level 10
Hi, when you defined the two vlans in the switch are you trunking from switch to router fe0/0 interface ?
Also when you difine encapsulation dot1q place the vlan # next to dot1q statement under the subinterface to define the vlan should be under.
e.g say you configured vlan 3 and vlan 4 on switch , the configuration in router should look like this.
interface FastEthernet0/0.3
description vlan 3
encapsulation dot1Q 3
interface FastEthernet0/0.4
description vlan 4
encapsulation dot1Q 4
Jorge
Jorge Rodriguez
Hi Jorge, thanks for helping,
I 've now the following:
interface FastEthernet0/0.1
encapsulation dot1Q 2
no snmp trap link-status
no cdp enable
interface FastEthernet0/0.2
no cdp enable
no cdp enable
and the show command , gives:
SugarDaddy# sh int fa 0/0.1
FastEthernet0/0.1 is up, line protocol is down
Hardware is Gt96k FE, address is 0017.590a.c122 (bia 0017.590a.c122)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 2.
SugarDaddy#sh int fa 0/0.3
FastEthernet0/0.3 is up, line protocol is down
Encapsulation 802.1Q Virtual LAN, Vlan ID 3.
SugarDaddy#
But there is no IP address, which i've aready inserted. Should i do it again?
Also, at the end will this traffic pass thorugh other switches like hp procurve ?
thanks for your help,
windieana
you said you configured the sub with IP addresses and yet they do not show up.. hmmm.. try re-entering again and write mem.
[edit]
how are you trunking from the wic switch , have you selected a port on switch to trunk with router and pass the two vlans you created on swithc, can you discribe the topology and where the hp connects to?
Jorge
Jorge Rodriguez
Jorge,
yes, you are wright, this time the ip addresses are configured on both interfaces.
But i'm able to test it because i'm remotly connected and the cables are not pluged.
Anyway, is this configuration enough ?
will it work with other manufacturer switches?
thanks again.
windieana
Hi Jorge
i'm not using any trunking and also these vlans on fa 0/0.1 and fa 0/0.3,should not comunicate.
do i need trunking? i heard trunk protocols on vlan on wic-4esw are not supported.
Each HP switch will connect to each fa0/0.x.
Here is my current config:
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip domain lookup
ip domain name wcupmobile.com
description used for internet access redundancy
no ip address
speed 100
full-duplex
ip address x.x.x.x 255.255.255.240
no cdp enable
no cdp enable
ip address y.y.y.y 255.255.255.248
no cdp enable
interface FastEthernet0/1
description Acesso Internet
ip address z.z.z.z 255.255.255.252
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 r.r.r.r
ip http server
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
no cdp run
thanks
w.
According to this doc WIC-4ESW supports 802.1q, you will need to trunk because you are using one physical port on router and spliting it with two routable subnets.
http://www.cisco.com/en/US/products/hw/modules/ps2641/products_module_installation_guide_chapter09186a008007cb78.html#wp1029307
you could create access-list on router to prevent the vlans talking to each other.
Jorge
Jorge Rodriguez
Hi Jorge , thanks for the reply.
But my config is not "pinging".
I cannot ping my interfaces fa 0/0.1 and fa 0/0.3.
Couls someone help?
Also ive check the doc , and it says:
WIC-4ESW Interface Card Platform Limitations
The following features are not supported on the WIC-4ESW interface card:
•Virtual Local Area Network (VLAN) trunking protocols (server and client modes, and transparent mode v2)
am i in the wrong direction?
windeiana
Hi Jorge,
i don't see the ports availble under vlan-switch,
what to do?
rg
windieana
SugarDaddy#sh vlan-switch
VLAN Name Status Ports
1 default active
2 vlan2 active
3 vlan3 active
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 1002 1003
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 1 1003
1003 tr 101003 1500 1005 0 - - srb 1 1002
1004 fdnet 101004 1500 - - 1 ibm - 0 0
1005 trnet 101005 1500 - - 1 ibm - 0 0
SugarDaddy#
it should as long the non cisco switches suport 802.1q standard.. and vlans you should be all set.. any questions we are here to help.
rate any helpful post if it helped
Rgds
Jorge
Jorge Rodriguez
