Cisco 2801 Question
Jherrera1004
I'm trying to open a port in a Cisco 2801, the port 3001 to give internet access for a cisco switch which IP is 172.16.8.40
thanks in advance
cisco 2801 config
match access-group 110
class-map type inspect match-all vpn-traffic
 match access-group 111
policy-map type inspect priv-pub-pmap
 class type inspect all-private
  inspect
 class class-default
  drop
policy-map type inspect pub-priv-pmap
 class type inspect vpn-traffic
  inspect
 class class-default
  drop
zone security private
zone security public
zone-pair security priv-pub source private destination public
 service-policy type inspect priv-pub-pmap
zone-pair security pub-priv source public destination private
 service-policy type inspect pub-priv-pmap
crypto isakmp policy 1
 encr aes 256
 authentication pre-share
 group 2
 lifetime 84600
crypto isakmp policy 5
 encr 3des
 hash md5
 group 2
 lifetime 84600
crypto isakmp client configuration group BFvpn
 key vPnBr1TT@ny9687!
 dns 192.168.2.10
 pool vpn_ip
 acl remotevpn
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set aes-256-sha esp-aes 256 esp-sha-hmac
crypto dynamic-map vpn 65535
 set transform-set ESP-3DES-MD5
crypto map vpn client authentication list AAA-VPN
crypto map vpn isakmp authorization list AAA-VPN
crypto map vpn client configuration address respond
crypto map vpn 65535 ipsec-isakmp dynamic vpn
interface FastEthernet0/0
 ip address 75.150.67.105 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip virtual-reassembly in
 zone-member security public
 duplex auto
 speed auto
 crypto map vpn
interface FastEthernet0/1
 ip address 172.16.250.1 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 zone-member security private
 speed 100
 full-duplex
interface FastEthernet0/3/0
 switchport mode trunk
 no ip address
interface FastEthernet0/3/1
 no ip address
interface FastEthernet0/3/2
 no ip address
interface FastEthernet0/3/3
 no ip address
interface Vlan1
 no ip address
interface Vlan413
 ip address 170.163.128.202 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
router eigrp 1
 network 172.16.0.0
ip local policy route-map LocalPBR
ip local pool vpn_ip 172.16.251.10 172.16.251.20
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static tcp 172.16.8.40 3001 172.16.250.1 3001
ip nat inside source route-map NAT-HFC interface FastEthernet0/0 overload
ip nat inside source route-map NAT-OPT interface Vlan413 overload
ip route 0.0.0.0 0.0.0.0 75.150.67.106 track 3
ip route 0.0.0.0 0.0.0.0 170.163.128.201 5
ip access-list standard remotevpn
 permit 172.16.0.0 0.15.255.255
ip sla 1
 icmp-echo 75.150.67.106 source-interface FastEthernet0/0
 frequency 30
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 170.163.128.201 source-interface Vlan413
 frequency 30
ip sla schedule 2 life forever start-time now
access-list 1 permit 170.163.0.0 0.0.255.255
access-list 1 remark for Telnet & SNMP Restrictions
access-list 1 permit 172.16.8.0 0.0.3.255
access-list 7 permit 172.16.8.40
access-list 7 permit 172.16.8.41
access-list 7 permit 172.16.8.42
access-list 7 permit 172.16.8.43
access-list 10 permit 75.150.67.105
access-list 20 permit 170.163.128.202
access-list 102 deny   ip any 10.0.0.0 0.255.255.255
access-list 102 deny   ip any 172.16.0.0 0.15.255.255
access-list 102 deny   ip any 192.168.0.0 0.0.255.255
access-list 102 permit ip 172.16.0.0 0.0.15.255 any
access-list 102 permit ip 172.16.0.0 0.15.255.255 any
access-list 110 permit ip any any
access-list 111 permit ip 172.16.251.0 0.0.0.255 172.16.0.0 0.15.255.255
access-list 111 deny   ip any any
route-map LocalPBR permit 10
 match ip address 10
 set ip default next-hop 75.150.67.106
route-map LocalPBR permit 20
 match ip address 20
 set ip default next-hop 170.163.128.201
route-map NAT-HFC permit 10
 match ip address 102
 match interface FastEthernet0/0
route-map NAT-OPT permit 10
 match interface Vlan413
snmp-server community chimenet#3000 RO 1
snmp-server enable traps tty
tacacs-server host 170.163.248.63
tacacs-server host 170.163.248.64
tacacs-server directed-request
tacacs-server key 7 06050728414B071C1154405B5C54
Mohit Sahai
Hello Jherrera,
Trust you are doing great.
Could you please additionally configure "ip nat outside" under interface Fastethernet 0/1 and "ip nat inside" under interface vlan 413 and interface fa 0/0 and check if the its working.
Mohit
**Please rate if you find this post helpfull
