CISCO 2811 Boot Problem
raschlosser
Visitor
Hi All,
i have an Cisco 2811.
Now the System hangs up in rommon (it works before).
I performed the boot flash: command and the system extract the IOS. But then the foolowing messages came up:
Queued messages:
*Aug 24 14:12:18.607: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Aug 24 14:12:18.551: %SMC-2-FAILED_ID_HW: Failed Identification Test in 0/-1/-1 [4/0]
c2811 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Readonly ROMMON initialized
rommon 1 >
As you see again in the rommon.
I removed all modules but it is still the same.
Did someone faced the same problen and saved it?
Thanks and Regards
Regards Ralf
Peter Paluch
Ralf,
It seems that your issue is similar to this one:
https://supportforums.cisco.com/message/3318783#3318783
Unfortunately, this seems to require a TAC assistance.
Best regards,
Peter
