Cisco 2811 high cpu load
Pascal Faucher
hi,
I'm facing a cpu load issue on cisco 2811.
you can see the configuration, there is nothing extra exhausting for the cpu.
Each time the traffic start to increase, the cpu load increase to 80 or 90% to reach 100%
each time a user start a download  on  for exemple  fa0/1.50  the cpu  increase up to 90%
In the sh process cpu sorted, there is nothing showing that something is wrong.
sh proc cpu sort | excl 0.00
CPU utilization for five seconds: 84%/75%; one minute: 74%; five minutes: 49%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
111   131960796 143316176        920  4.59%  4.71%  4.39%   0 IP Input
177     1767464 342056427          5  0.98%  1.18%  1.19%   0 HQF Shaper Backg
  19     8909968  23942550        372  0.65%  0.57%  0.57%   0 ARP Input
304      575244  44231492         13  0.32%  0.32%  0.32%   0 PPP manager
305      407260  44473628          9  0.24%  0.19%  0.18%   0 PPP Events
268     5208776  20651063        252  0.24%  0.07%  0.08%   0 CCP manager
   2      124544    286211        435  0.16%  0.16%  0.10%   0 Load Meter
152       14188     54467        260  0.16%  0.06%  0.02%   0 TCP Protocols
300      499012   3859685        129  0.16%  0.16%  0.12%   0 IP NAT Ager
211       37756     28283       1334  0.16%  0.03%  0.05%   0 Crypto Support
110      251624  43851348          5  0.16%  0.14%  0.14%   0 IP ARP Retry Age
104      252316  43851416          5  0.16%  0.15%  0.16%   0 ACCT Periodic Pr
  42      837160   1446317        578  0.16%  0.16%  0.14%   0 Per-Second Jobs
145      176976   2185576         80  0.08%  0.08%  0.08%   0 CEF: IPv4 proces
CEF is enable on all interface
ICMP unreachables are always sent on all interface
I think but not sure  Trunk with Dot1q interface are not support in CEF
and I think is a switching  problem
fa/0/0 is my outgoing interface:
FastEthernet0/0 is up, line protocol is up
  Internet address is x.x.x.x/26
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are never sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF, Full Flow
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  BGP Policy Mapping is disabled
  Input features: Stateful Inspection, Ingress-NetFlow, Virtual Fragment Reassembly, IPSec input classification, NAT Outside, MCI Check
  Output features: CCE Output Classification, Post-routing NAT Outside, Stateful Inspection, IPSec output classification, Firewall (NAT), Firewall (inspect), Post-Ingress-NetFlow, IPSec: to crypto engine, Post-encryption output features
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
interface FastEthernet0/0
description WAN-INTERNET
mac-address 0020.40ff.f184
ip address x.x.x.x. 255.255.255.192
no ip redirects
ip flow ingress
ip nat outside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
crypto map vpnmap
Fa0/1 is a trunk interface with  10 subinterface.
FastEthernet0/1.150 is up, line protocol is up
  Internet address is x.x.x.x/23
  MTU is 1500 bytes
  IP fast switching on the same interface is enabled
  Network address translation is enabled, interface in domain inside
  Input features: Stateful Inspection, Ingress-NetFlow, Virtual Fragment Reassembly, MCI Check
  Output features: NAT Inside, Stateful Inspection, Firewall (NAT), Firewall (inspect), Post-Ingress-NetFlow
interface FastEthernet0/1.150
description LB-MGMT
encapsulation dot1Q 150
ip address x.x.x.x 255.255.254.0
no ip redirects
ip flow ingress
ip nat inside
Any idea how this issue can be resolved
Pascal
5 Replies 5
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
A 2811 is a software based router, so as you push traffic through it the CPU has to process it.  I.e. as traffic throughput increase so does CPU load.
Most of the ISRs are oriented for WAN routing, not LAN routing.  The difference being, WAN routing often works with lower bandwidth links than typically found on a LAN.  I recall (?) Cisco's recommendation for the 2811 was no more than dual T1s.  (I've seen a 2811 on a full T3 max its CPU out at about 20 Mbps, duplex.)
Since you're using FastE interface, how much bandwidth are you pushing through the 2811 when you see the CPU load you've documented?
Hi Joseph,
Thanks for your answer,
Not more than 15Mb and the cpu increase, maybe I should put a 3750 behind for the lan routing  and let the 2811 do wan routing only.
Or maybe a 1941/2901  should do the job or put a 1811,
1811 will do more throughput than the 2811 in the real world because of its much more powerfull processor.
Pascal.
Disclaimer
Posting
For small LANs with WANs, I often suggest a small L3 switch and a WAN router.
If you're seeing this high CPU at only 15 Mbps, might also be due to other sevices.  Looks to me you might also being doing NAT and VPN.(?)
As to relative performances of the routers you've noted, Cisco lists their performance as:
1811 70 Kpps
2811 120 Kpps
1941 299 Kpps
2901 327 Kpps
Yes
Other service like  VPN and NAT are running.
I'm looking for  1941/2901 , I have around 150pc behind and 20 server  or put 3750G behind and keep my 2811
Disclaimer
Posting
The 3750G will only really help if it keeps some traffic from needing to go to the 2811.  If all your 150 PCs and 20 servers on the same subnet, traffic between them doesn't need to be routed.  If they are on different subnets, then a 3750G should support much, much more throughput among them.
