Flexible QOS limit for 2 hosts.
roger perkin
Level 2
Level 2
I have 2 x 6500's connected via a 100MB Les circuit between our main and DR sites.
There are 2 nodes which pass 95% of the traffic on this link which is data replication.
I have setup a policer on the port channel to restrict the traffic to 75MB
however the other node is now transmitting and I assume my policy is policing them both to 75, so they actually swamp the link.
What I want to be able to do is to permit nodeA to have 75Mb BW if it is available, however if NodeB starts talking to only allow them 75 between them.
The other 25 is for BAU traffic
sh class-map
Class Map match-any class-default (id 0)
   Match any
Class Map match-any S2S (id 2)
   Match access-group name S2S
sh policy-map
  Policy Map S2S
    Class S2S
     police cir 70000000 bc 2187500
       conform-action transmit
       exceed-action drop
Extended IP access list S2S
    10 permit ip host 10.251.225.66 any (15 matches)
    30 permit ip host 10.251.225.67 any (6 matches)
interface Port-channel100
description Site to Site Connection
service-policy output S2S
Roger
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
What you desire might not be possible unless you have have the QoS features of a 6500 WAN type card.
Even if you did have complete QoS features, since policer's don't queue, not sure you could do it even then.  With full QoS features, you would be able to do something close to what you describe using a shaper and hierarchal policy.
If you're using LAN cards, one that supports at least 2 queues, you could change weights to guarantee 25% bandwidth to BAU traffic, then remaining bandwidth to be split evenly between hosts A and B.  (NB: with guarantees, I will often invert the proportions, i.e. guarantee 75% to BAU and 25% to hosts A and B, since either can use the others unused bandwidth.)
