Cisco 2811 NAT configuration Issue!!!
orlandoegb
My company have a EDI service from a provider with a fiber optic that was installed in our building some weeks ago. They're using the ISP switch from us to their router and I have the router behind the switch to my Private Network:
(My LAN)<---->(My Router)<---->[ISP_Switch]<----------FO-------->(ISP_Internet Router Gateway)
After we have done " the configuring" on the router. I am able to trace/ping/etc. from the router, however I am unable to do any of the above from my Private LAN that is connected to the router.
The NAT config on my router looks as such:
interface FastEthernet0/0
description LAN to ISP Gateway ***$ETH-WAN$
ip address a.b.c.d 255.255.255.252
ip nat outside
duplex full
speed 100
interface FastEthernet0/1
description LAN to My Local-Internal Network ***$ETH-LAN$
ip address x.y.z.1 255.255.255.0 secondary
ip address 10.100.1.47 255.255.0.0
ip nat inside
duplex auto
speed auto
no ip classless
ip route 0.0.0.0 0.0.0.0 a.b.c.d (ISP Internet Router Gateway)
ip http server
ip nat translation timeout 3600
ip nat pool test x.y.x.11 x.y.x.16 prefix-length 24
ip nat inside source list 101 pool test overload
access-list 101 permit ip host 10.100.51.55 any log
access-list 101 permit ip host 10.100.51.54 any log
Thanks and we appreciate any help!!!
Orlando
Reza Sharifi
Can you add an access list to allow 10.100.1.0/24
access-list xx permit 10.100.1.0 0.0.0.24
ip nat inside source list 1 pool ovrld overload
ip nat pool ovrld x.x.x.x x.x.x.x prefix 24
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
