11-05-2012 08:37 AM - edited 03-07-2019 09:51 AM
Dear All,
I would like to know how many and what are the Cisco Switches that supports L3 Routing...
Yaseen
Solved! Go to Solution.
11-05-2012 01:31 PM
I ain't going to talk about the Linksys line because I have very limited knowledge of their capabilities.
In regards to the Cisco Catalyst range, the 3560-, 3750-, 4500-series switches are Layer 3 capable. All you need is to enable the right feature set.
The Catalyst 2960/G/S is capable of running static routing if you run the correct IOS.
11-05-2012 09:03 AM
Almost all of them. The SMB switch are usualy L2. You need to look at the datasheet to find out.
11-05-2012 01:31 PM
