ā08-17-2016 11:29 AM - edited ā03-08-2019 07:02 AM
I am trying to configure a port channel on a Cisco 2911 with switch module installed. I am trying to use the switch modules interfaces but I don't have any option for channel-group under the interface mode. The router has ipbasek9. Do I need different license in order to do port channel on the switch module?
ā08-18-2016 12:36 AM
what's the switching module you have in place , you can see it with show inventory
there supported in 2811 etc so should be in 29s but certain ios is required
Have you checked the on-board ports do they support it ..channel-group ?
what version of ios are you currently on
http://www.cisco.com/c/dam/en/us/products/collateral/routers/3800-series-integrated-services-routers-isr/prod_white_paper0900aecd806f698a.pdf
ā08-18-2016 06:40 AM
The switching module is 4 Port GE Non-POE EHWIC (EHWIC-4ESG) and the IOS is c2900-universalk9-mz.SPA.155-1.T2.bin. I was able to configure the on-board port as a layer 3 port-channel, but when connecting them to the 6800 chassis, they never come up. Note that this is a voice router, I need to keep an IOS that will recognize the voice modules too.
ā08-18-2016 07:15 AM
doesn't look to be an IOS problem but a module problem , very forum I check aswell says its no supported
The main data sheet from Cisco doesn't show it as supported in its list of features either for that module ....802.3ad
https://supportforums.cisco.com/discussion/11897676/cisco-3945-channel-group-switching-interfaces-ehwic-4esg-module
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/qa_c67-612908.html
Whats happening with the 6800 why is not coming up do you get an alert either side have you tried pagp and lacp and force mode on , are they in VSS mode or are you connecting standalone to one chassis
ā08-18-2016 09:22 AM
Correct. EHWIC doesn't support port-channel, only etherswitch network modules and service modules support etherchannel configuration. Also there is no etherswitch module for 2900 routers.
